chip
By temp settings, I mean in conjunction with program injection curves. By that I mean might make your injector pulse rates a little wider @ cooler engine temperatures. Wider pulse rates mean more fuel, however slight that might be to maintain fuel efficiency[8D]
ORIGINAL: joecls
when you say it changes the temp settings, does this mean a lower degree thermostat must be used as well? i see some of these programmers include a 160 thermostat. how does that help the performance of the engine?
Hope this is what you are talking about Joecls - these are the ones under your console or from storage bin compartment.
RPO codes:
1YY07 - Base Coupe
1YY67 - Base Convertible
1AZ - Modification stock order or order sold
1SB - Marketed option package 2
24S - "Removable Roof Panel, blue tint"
64S - "Removable Roof Panel, bronze tint"
AC1 - Power Passenger Seat
AC3 - Power Driver Seat
AJ3 - S.I.R. system (driver side only) 90-93
AK5 - Front seat S.I.R. system (driver & pass.) 94-96
AQ9 - Leather Sport Seats
AR9 - Base Leather Seats
AU3 - Power Door Lock System
B2K - Callaway Twin Turbo Engine (on Bowling Green Twin Turbos)
B4P - Fan, Aux Cooling, Electric
BGR - Bowling Green assembly plant
C05 - convertible folding top
C2L - Dual Removable Roof Panels
C49 - Electronic Rear Window Defogger
C60 - Manual Air Conditioning Controls
C68 - Electronic Climate Control
CC2 - Auxiliary Hardtop (convertible only)
CC3 - Removable Plastic Roof Panel
CF7 - Removable Roof Panel (Solid Body Color)
D3X - Speedometer Driven Gear (25513049)
D4L - Speedometer Driven Gear (25513050)
D7B - Speedometer Driven Gear (25513043)
D7C - Speedometer Driven Gear (25513045)
D8E - Vehicle Speed Sensor (10456021)
D8F - Vehicle Speed Sensor (10456022)
D8H - Vehicle Speed Sensor (10456039)
DC7 - Electronic LH & RH Outside Mirrors
DC8 - Electronic LH & RH Outside Mirrors
DL5 - roadside service information decal
DL8 - LH/RH Heated Sport Mirrors
E5C - Delete speedometer adaptor
E9Z - Delete speedometer key
EXP - Export
F45 - Adjustable Suspension
FE1 - Base suspension
FE3 - sport suspension (96 Z51)
FE7 - Heavy Duty Suspension
FE9 - federal emissions
FX3 - Adjustable Suspension
G44 - 3.07 Rear Axle Ratio
G87 - ring gear 8.50 inch
G92 - Performance Axle Ratio
GHO - 3.54 axle ratio
GM1 - 2.59 Rear Axle Ratio
GM3 - 3.45 Rear Axle Ratio (8.5 in. Ring Gear)
GT7 - 3.33 rear axle ratio
GU2 - 2.73 Rear Axle Ratio
IP3 - Interior trim design P3
J55 - Heavy Duty Brakes
JL9 - Antilock Front and Rear Disc Brakes
K05 - Engine Block Heater (Canada Export only)
KC4 - oil cooler
KG9 - 140 amp generator
KW2 - 124-Amp Generator
L83 - 1984, standard engine, Crossfire, 350ci, 205 hp.
L98 - 1985-1991, standard engine, 350ci, 230~250hp.
LT1 - 1992-1996, standard engine, 350ci, 300 hp.
LT4 - 1996, optional engine, available only with manual transmission, 330hp
LT5 - 1990-1995, optional engine, part of ZR1 package, 375hp, in 1993, upped to 405hp.
MD8 - 4-Spd. 4L60 Automatic Transmission
ML9 - manual 6-speed, ZF-transmission
MN6 - 6-speed manual transmission
MX0 - automatic transmission
NA5 - Federal Emission systems
NK4 - Sport Leather Steering Wheel
NN5 - California Emission Requirements
QA1 - Wheel, 17 x 9.5, Aluminum
QA2 - Wheels, 17 x 9.5 (Front) 17 x 11 (Rear), Aluminum
QB6 - aluminum wheels 17 x 8.5" front, 17 x 9.5" rear
R9Z - Control sales item 100
T61 - Daytime Running Lights
U19 - Miles & Kilometers Dash Cluster
U1F - Delco Bose Stereo System w/ CD
U52 - Electronic Instrument Cluster
U75 - Power Antenna
UJ6 - Low Tire Pressure Warning System
UM6 - "Bose Stereo w/ CD & Cassette, Seek/Scan, Clock, ETR Radio"
UU8 - Delco Bose Stereo System
UXO - Dual Floor Sill & Extended Range Speaker System
VM3 - information label, bumper impact standards
V56 - Luggage Rack (convertible only)
V73 - Vehicle statement, US or Canada
XAA - front tire P255/45 ZR17
XAU - Front Tire, P275/40ZR17
YAA - rear tire P285/40 ZR17
YAU - Rear Tire, P275/40ZR17
YBE - Rear Tire, P315/35ZR17
Z07 - Handling suspension
Z51 - Handling suspension
Z52 - Handling suspension
Z5G - Identification, Callaway Orders (not listed on SPI label all years)
ZR1 - Special Performance Pkg.
Colour codes:
Exterior
10U - Arctic White exterior
Interior
70I - Torch Red interior
703 - Torch Red leather
RPO codes:
1YY07 - Base Coupe
EXP - Export
KC4 - oil cooler
U75 - Power Antenna
Colour codes:
Exterior
Interior
