Clutch Problem?
Old Jan 10, 2008 | 12:15 PM
95trplblkandtan's Avatar
Default Clutch Problem?
Hey guys, got a quick question. I keep running out of fluid in my hydraulic clutch. I have a 95 manual, so the resavoir is right underneath the computer. I can't seem to find anything leaking, as their are no drips coming from around there. Any Ideas?
Old Jan 10, 2008 | 02:28 PM
YANKEECORVETTE's Avatar
Default RE: Clutch Problem?
Check under the dash where the push rod connects to the pedal. See if the back of the clutch master cylinder is wet. If not check on the slave cylinder on the bellhousing. One or the the other blew a seal or you have aloose fitting or the reservoir is leaking.
Old Jan 18, 2008 | 08:50 AM
Thanks, ill check those... any other opinions?
Old Jan 18, 2008 | 02:44 PM
extanker's Avatar
he hit it all unless someone is poppin yer hood and stealin it
Old Jan 19, 2008 | 05:41 PM
well i hope thats not the case... im just having trouble locating where the leak is, ive checked these places and i don't feel it being wet or see a leak
Old Jan 23, 2008 | 12:28 AM
ken93vette's Avatar
I never did find a leak with my clutch system, I replace both the master and slave and all is good. Had a heck of a time finding a good slave as you see from the clutch threads that some of them have been remanufactured with the seals backwards. Good Luck
Old Jan 31, 2008 | 10:30 AM
I replaced the master cylinder this weekend and that seemed to have taken care of the problem... It looked like it was going to be a pain in the ***, but i just pulled the battery out and it was easy to get too... i did have some fun getting up underneath the dash to disconnect the clutch pedal though... wish i had a picture of that one...
jerseyc5
May 14, 2008 08:19 AM
Spawn
Nov 27, 2006 01:35 AM
reactor2
Sep 4, 2006 09:33 PM
jafone
Jun 12, 2005 11:43 AM
crausch
May 25, 2005 03:31 PM
