Compression check with intake removed????
Old Nov 21, 2021 | 05:27 PM
stanleyz's Avatar
Default Compression check with intake removed????
Any reason I can't or shouldn't do a compression check with intake manifold removed. Only thing I can think of is I will have to realign the distributer when I reassemble. I am trying to decide if I should have thee head rebuilt while I have the rest of the top end off. Everything looks good and I have no real reason to think there is a problem but It's not a lot more work.
Old Nov 22, 2021 | 11:01 AM
I can't think of any reason that you couldn't do that. Maybe someone else can chime in here with other thoughts.
Old Nov 22, 2021 | 07:32 PM
Northwoods79's Avatar
Can’t think of any reason why you couldn’t do it, you’re correct in the big thing is getting #1 cylinder to TDC and reinstalling the distributor in the correct firing order
Mac Rosel
Feb 11, 2015 02:50 PM
harleymarkt
Mar 13, 2008 10:25 PM
whiteray
Feb 8, 2007 11:11 AM
jph
Jan 14, 2007 09:36 AM
Krayon
Nov 5, 2005 09:24 PM
