cylinder head ft lbs.
Old 04-09-2007, 12:31 AM
jph's Avatar
jph
jph is offline
Default cylinder head ft lbs.
Installed the heads back on my 89. The Chilton manual calls for the long bolts to be torqued to 60-75 and the short bolts 55-65. is thisa range, or should the final be 75 and 65? Seems strange that the bolts have a different torque setting. Right now I have all bolts set at 65, doI increase the long bolts to 75?
Old 04-09-2007, 01:29 AM
Default RE: cylinder head ft lbs.
interesting question.just checked a chilton manual i have and it says 45 onthe first pass,74 on the second and 118 on the final and does not differentiate between aluminium and cast heads or long and short bolts.The haynes manual says 65 cast iron long and short,65 long 60 short with aluminium.My mercruiser manuals(350 small block) go with the 118 cast iron!!
When I rebuilt my stroker I went with the lower(65) settings and nothings popped yet 'tho it seemed very low to me.Thats aluminium heads.
Old 04-09-2007, 12:18 PM
jph's Avatar
jph
jph is offline
Your looking at the Vin J engine, mines the Vin 8. Thanks for the comments. The Vin J motor were biult by mecury marine, they need
lots of torque to hold those puppies together.
ppwertime
10-30-2006 05:45 PM
ppwertime
10-30-2006 05:45 PM
57halfton
09-05-2006 02:49 AM
importkiller69ss
02-21-2006 02:14 PM
79vette
12-07-2005 01:51 PM
Quick Reply: cylinder head ft lbs.
