Distributor rotor screws
Can someone tell me what kind and size of head is on the rotor screws. I am changing the water pump and capa nd rotor on my 95.I'm at a standstill right now. Looks like a small torx head but i can't get a bit to fit,and I have them all.Any help would be appreciated.
Thanks Mike |
RE: Distributor rotor screws
mike not sure on a 95 but my 90 is a 1/4 " socket, hope this helps
Thanks for the reply, but these screws do not have a hex head.They have a recession.Tried to take pic so I could see what they are but the shot is to close.Anybody else?
It's a Torx E4 deep socket. I got mine at the Auto Parts store. I think Vulcan is the brand. You might want to try Snap-on.
I just looked it up in the Snap-on catalog-It's a 1/4" drive deep Torx socket E4 Part # STLE40 |
Turns out it was a T-8 Torx. The newMSD cap came with allen screws.
How many miles are on the opti that you put a new cap and rotor on? Why in the world would you just do a cap and rotor when you already had the water pump offand the engine tore down? If your going that deep you might as well do a whole new opti. Spend the extra cash and get a whole new opti instead of spending a couple hundred bucks fopr a cap and rotor which you will probably have to go back and put a whole new opti on sooner more than later. Just replacing the cap and rotor is a waste of time and money........
ORIGINAL: LeesVette How many miles are on the opti that you put a new cap and rotor on? Why in the world would you just do a cap and rotor when you already had the water pump offand the engine tore down? If your going that deep you might as well do a whole new opti. Spend the extra cash and get a whole new opti instead of spending a couple hundred bucks fopr a cap and rotor which you will probably have to go back and put a whole new opti on sooner more than later. Just replacing the cap and rotor is a waste of time and money........ |
I have 73000 miles on the 95. It really wasn't that bad of a job. I have a side business repairing.What brand of Opti do you recommend. Stock or aftermarket? The cap and rotor are MSD pieces.
ORIGINAL: xfasteddiex ORIGINAL: LeesVette How many miles are on the opti that you put a new cap and rotor on? Why in the world would you just do a cap and rotor when you already had the water pump offand the engine tore down? If your going that deep you might as well do a whole new opti. Spend the extra cash and get a whole new opti instead of spending a couple hundred bucks fopr a cap and rotor which you will probably have to go back and put a whole new opti on sooner more than later. Just replacing the cap and rotor is a waste of time and money........ |
ORIGINAL: camhar25 I have 73000 miles on the 95. It really wasn't that bad of a job. I have a side business repairing.What brand of Opti do you recommend. Stock or aftermarket? The cap and rotor are MSD pieces. |
