Door Lock Actuator question
Old Mar 31, 2006 | 11:59 AM
LeesVette's Avatar
Default Door Lock Actuator question
I had a keyless entry system installed on my '92 and I was told I need a passenger side door lock actuator. Anyone know how to do this repair, how difficult it is and how much I can expect to pay for parts. Any help would be greatly appreciated. I have a Helms manual ordered but have not got it yet. Thanks!
Old Mar 31, 2006 | 09:31 PM
Default RE: Door Lock Actuator question
Actuator's run about 80-100 bucks new. Don't get a rebuilt one, because the job is a little tedious to do. Have to pull door panels (inner and outer), drill out the rivets that hold the actuator to the door frame and if you don't have the big rivet gun to do 3/8 rivets, need to beg, borrow or steal (j/k) one, because you don't want to bolt it in cause the bolts will eventually loosen up. You can probably change one out in a couple of hours. [8D]
Old Apr 1, 2006 | 12:08 AM
LeesVette's Avatar
Thanks Mech! ( I knew I could count on you)
Old Apr 1, 2006 | 01:27 AM
Anytime. Glad to be of help. Always like to pass on knuckle skinnin stuff. [8D]
Old Apr 1, 2006 | 05:49 PM
redvet's Avatar
Hey Leesvette - A question on the installation of the keyless entry. I am looking to install a keyless entry on my 92 also. What brand of system did you install? Thanks for the info.
Old Apr 1, 2006 | 11:38 PM
LeesVette's Avatar
It was a cheap system - Auto Page.
Old Apr 2, 2006 | 01:46 PM
redvet's Avatar
Thanks LeesVette. I would like to install one in my 92 and hoping to find an aftermarket system that works. One last question - did you encounter any major problems when installing? Thanks again for the information.
Old Apr 2, 2006 | 07:06 PM
LeesVette's Avatar
I had it installed by a "professional" That is an oxymoron - now when you use it to unlock the "door" since the passenger side isn't working it sets off the "panic" mode (horn starts blasting, ligths flash) and it doesn't unlock the door! I have to get the key in the lock and when I turn the key in the lock the alarm does shut down so I would say I have a few "bugs in the system" to say the least! I have to get it back in the shop - soon! When you lock it with the keyless - the door chime doesn't stop pinging and the parking/fog/running lights won't quit flashing. This thing is so sick and screwed up it doesn't know if it should roll down its socks or take a ****.
Old Apr 4, 2006 | 02:37 AM
You should have someone with a scantool capable of reading body codes check your passlock system. We have a Tech 2 scanner for GM vehicles which works fine, but someone who has knowledge of the passlock system. You may have a bad door switch or a bad ignition key reader. Have it checked to try and avoid the "shotgun" approach to fixing it. [sm=badidea.gif]
Old Apr 4, 2006 | 02:04 PM
LeesVette's Avatar
Okay, I got to ask - what is the "shotgun" approach?
