factory rev limitor.
ORIGINAL: kennyk
how do i get around the factory rev limitor ?????????
and what is a good chip to replace the factory chip. if this is the best thing to do.
Save yer $$$.Ya' never know when yer gonna' take a hi-$$$ maintenance hit.
Get a custome chip burned for your car AFTER you have done some decent mods. Don't waste your money on a Hypertech chip or any other aftermarket, generic chip. If you must get one now, get a custom chip burned from someone like Alvn at PCMForLess.com.
Unlessyour wanting that car to turn more than 5800 RPM's then I wouldn't worry about the rev limiter. Also, if your just now thinking about a chip I figure the car is pretty much stock. That limiter is there for a reason and it sounds like you need it right now.
hi guys , i have a 92 LT1 with exaust ,cam, injectors, intake mods,throttle body. car runs great but , the rev limiter is holding me back.the engin is capable of 7500 but can,t get there.
any info. is greatley appreacheated.
That rev limiter maybe holding you back some but if your going to spin it higher than the limiter you probably want to do the bottom end. I don't know how you are going to get around the limiter with an OBDI car.
ORIGINAL: kennyk
ORIGINAL: kennyk
If you ARE gonna' race, even then, get a dynomometer printout, to see what your motor is doin at 6K rpm. If HP, and torque curves have peaked by the time the twister hits 6k, there's no reason to even think about it.
If the curve is still goin' up at 6k, then maybe it would be the thing to do. Maybe.
