factory rev limitor.
Old Sep 1, 2007 | 11:41 PM
kennyk's Avatar
Default factory rev limitor.
how do i get around the factory rev limitor ?????????
and what is a good chip to replace the factory chip. if this is the best thing to do.
Old Sep 2, 2007 | 01:50 AM
d93vette's Avatar
Default RE: factory rev limitor.
was up, i think the rev-limiter for the vettes from 87-94 was chip controled[obi1] were after can be changed with a handheld unit.[obi2]
Old Sep 2, 2007 | 08:19 AM
ORIGINAL: kennyk
Welcome in to the forums there!
Save yer $$$.Ya' never know when yer gonna' take a hi-$$$ maintenance hit.
Old Sep 2, 2007 | 02:11 PM
9340Vette's Avatar
I agree with CWB!
Old Sep 2, 2007 | 04:52 PM
LeesVette's Avatar
Get a custome chip burned for your car AFTER you have done some decent mods. Don't waste your money on a Hypertech chip or any other aftermarket, generic chip. If you must get one now, get a custom chip burned from someone like Alvn at PCMForLess.com.
Unlessyour wanting that car to turn more than 5800 RPM's then I wouldn't worry about the rev limiter. Also, if your just now thinking about a chip I figure the car is pretty much stock. That limiter is there for a reason and it sounds like you need it right now.
Old Sep 2, 2007 | 10:18 PM
kennyk's Avatar
hi guys , i have a 92 LT1 with exaust ,cam, injectors, intake mods,throttle body. car runs great but , the rev limiter is holding me back.the engin is capable of 7500 but can,t get there.
any info. is greatley appreacheated.
Old Sep 3, 2007 | 03:00 PM
LeesVette's Avatar
That rev limiter maybe holding you back some but if your going to spin it higher than the limiter you probably want to do the bottom end. I don't know how you are going to get around the limiter with an OBDI car.
Old Sep 3, 2007 | 04:02 PM
Eggster's Avatar
ORIGINAL: kennyk
You may need an aftermarket Opti. I have a 92 as well and I just bought an MSD opti that is 10,000 rpm capable. I'm not sure what the limits of the stock unit are.....
Old Sep 7, 2007 | 12:50 AM
84corvetteC4's Avatar
welcome and from all of my experience you dont want to "get around the factory rev- limiter it WILL save your engine if you miss a shift[:@]
Old Sep 7, 2007 | 01:08 AM
ORIGINAL: kennyk
I'm with everybody else here. Don't re-write the computer's limiter.
If you ARE gonna' race, even then, get a dynomometer printout, to see what your motor is doin at 6K rpm. If HP, and torque curves have peaked by the time the twister hits 6k, there's no reason to even think about it.
If the curve is still goin' up at 6k, then maybe it would be the thing to do. Maybe.
