fuel pump relay
Old Sep 6, 2007 | 11:52 AM
  #11
rshiver's Avatar
Default RE: fuel pump relay
Hey cwb...whats it like having a birthday everyday??
Old Sep 6, 2007 | 12:54 PM
  #12
ORIGINAL: rshiver
Hey shiver!
Yeah I'm kinda' diggin' that a little bit. Ya' oughtta' give it a try! Now I can justify buyin' more toys?
Old Oct 9, 2007 | 03:49 PM
  #13
dfwgsx's Avatar
so i was thinking about it and if it were leaky injectors would it still start up in the mornings on the first turnover? Cause if i let it sit overnight and go out there it starts up on the first try. But i also know that it should be starting right at the turn of the key, like it use to.
Old Oct 9, 2007 | 05:07 PM
  #14
rshiver's Avatar
Hi dfwgsx. yea mine does, and I know I have at least two leaking. A cold engine likes a rich fuel mixture. It's onlyafterI've been driving it a while, and then let it set for 30 minutes or so is when it has to turn over several times before it catches. I can smell the rich exhaust too.
Can you hear the fuel pump when you turn the key on?
Old Oct 9, 2007 | 05:14 PM
  #15
ORIGINAL: dfwgsx
Yes.
Leakin' injectors will allow fuel to drip into the ports, then run into the cylinders, until the residual pressure of the fuel in the fuel line is relieved. In the AM, the cold motor will still start right away. In the summertime, a hot motor might hesitate to re-start, depending how long its been off.
Get someone to pull the trigger for ya', while ya' watch the exhaust, on a cold AM start-up. A heavy black puff, for a moment, is a leaky injector(s).
Old Oct 9, 2007 | 05:35 PM
  #16
dfwgsx's Avatar
yep defintely a puff of black smoke and my tips of my exhaust are turning black as well. While the car is running will leaky injectors make it run rich as well? Also what would be the correct fuel injectors for it such as 24lb or 26 lb, 28lb etc. Its a 95 lt1 vette
Old Oct 9, 2007 | 06:45 PM
  #17
rshiver's Avatar
I'm sure cwb knows more about this than I do, but I think they came stock with 22lb, he can correct me if I'm wrong.From what I understand, 24lb will work on a stock motor too, but would probablydo better on a slightly modified motor. Plus, I think the aftermarket 24lb are cheaper than the factory 22lb.
Old Oct 9, 2007 | 06:52 PM
  #18
dfwgsx's Avatar
i called a shop and they quoted me at 175/ injector. too much for me so i bought a brand new set with a warranty on ebay
Old Oct 9, 2007 | 08:06 PM
  #19
rshiver's Avatar
175.00 for each ?? or is that to install them too?
I priced somenew stock replacements from Bumper To Bumper auto parts for around 90.00 each, andrebuilt for around 400.00 a set of 8
Old Oct 9, 2007 | 08:16 PM
  #20
dfwgsx's Avatar
no that was just to order them for me not replace them.
