headlight relays
Old Sep 14, 2006 | 06:08 PM
bill's Avatar
Default headlight relays
hi guys if your headlight relay is bad would that cause the motor to spin a gear and if so where do i look for it to replace it i put a new gear inn the drivers side bout 3-4 weeks ago worked fine bout 3-4 days ago turned it on the d/side didnt want to go up then when it did the motor kept running so im back to the lights in the up position (WHICH I HATE [:@]) TILL I CAN FIGURE OUT WHY IT WENT AGAIN AND CAN GET IT FIXED thanx again
Old Sep 15, 2006 | 01:59 AM
Default RE: headlight relays
Did you replace the gear with the metal updated version?
Old Sep 15, 2006 | 03:43 AM
redvette89's Avatar
Ecklers carries the headlight relay for about 14 bucks.
I'm having the same problem on my 89. It staarted with the left side. then the right.
Some days they both work fine. Eclers also carries a headloght accuator module.
You wouldn't happen to know what that does?
Old Sep 15, 2006 | 08:16 AM
Is the headlight free wheeling? Can you move it by hand? If so then the gear is messed up. If you can manually operate the headlight, then you have a power problem. I'll get back to you on relay location.
Old Sep 15, 2006 | 08:17 AM
BTW, what year is your car?
Old Sep 16, 2006 | 03:45 AM
redvette89's Avatar
Sorry Bill I misunderstood your question. I thought you were looking for a source for the relay
not the location of it in the car.
Old Sep 16, 2006 | 10:49 AM
bill's Avatar
the car is an 85 and i can turn the light by hand but like i said it makes an awful grindin noise like it did b4 i changed it thats why i think i spun another gear replaced w/ a new set of plastic gears from ecklers ,,, do you think i should use the brass or bronze ones next also i have a guy @ work makin me a new gear from some kinda heavy plastic they use so he'll make a pattern box and then all ill have to do after that for the small gear is pour the plastic in it and wait if the first 1 he makes works
Old Sep 17, 2006 | 11:53 PM
Use the brass upgrades, that's why they made them because the recurring problems with the plastic ones.
Old Sep 18, 2006 | 08:24 PM
bill's Avatar
thanx again 4 the help brass it is ill let ya know what i find when its done
Tarheel1
May 23, 2013 06:26 PM
Henmtrsports
Oct 28, 2008 10:50 AM
jchambers
Jan 29, 2008 05:54 PM
marty.g
Jan 4, 2008 11:40 PM
jdavis
Sep 3, 2005 11:29 PM
