Home made Air Bracket
Old Nov 19, 2006 | 12:01 PM
Black86vette's Avatar
Default Home made Air Bracket
I found this and thought it would it was really interesting. It might save some of you guys money wanting to do this.
The cross-section of the bars was determined by the stuff I could find in my scrap box, so anything similar will probably do, providing it is strong enough. The bolt holes through the bar are sleeved with a bit of tubing, to prevent the bar from collapsing when the bolts are tightened.
The pulley is A Dayco 00032 (thanks to War Machine for that!)
The main bar is 40 x 20 mm, and started life as a shop display stand - wall thickness about 2mm. The alternator brace is 20 x 10mm solid aluminium alloy, and was part of an old photocopier.
The bolts are 118mm long, (not including head), 22mm of which is threaded. Bolt diameter is 9.5 mm (3/8"). I got them from my "magic bolt box", they probably came from a Chevy engine in the first place, possibly starter mounting bolts by the look of them. Don't know what the thread is, approx 16 TPI
[IMG]local://upfiles/3722/DA3644C4525B41CD88A60F9DF93BED41.jpg[/IMG]
[IMG]local://upfiles/3722/0DBB58AED0AD4A0C87923194BF04821F.jpg[/IMG]
[IMG]local://upfiles/3722/FB850C913DF2491792F99359346825BE.jpg[/IMG]
[IMG]local://upfiles/3722/B4B321B48CEA442C9A9D686E3C6F0D7F.gif[/IMG]
SCHOON
Feb 1, 2007 10:33 AM
Z 51
Feb 25, 2006 11:20 AM
StrayDog
Feb 8, 2006 09:47 PM
Danase
Dec 23, 2005 10:59 PM
bmbndb
Sep 26, 2005 07:07 PM
