Horn
Old Oct 7, 2020 | 03:54 PM
hicksi@ptd.net's Avatar
Default Horn
How to bench test horns on a 1984 corvette ?
Old Oct 9, 2020 | 10:14 AM
All you need to do is connect 12 volts to the terminal and ground to the frame of a horn. If it fails to honk with that set up then you can turn the adjusting screw a little bit in either direction and see if it will break loose the diaphragm.
gary1984
May 17, 2016 08:45 PM
84blackice
Oct 12, 2007 10:46 PM
lumpsdady
Apr 22, 2007 04:33 AM
c3vetteman
Aug 25, 2006 03:19 AM
my1fast99c5
Jun 7, 2006 12:21 PM
