Idle not adjusting, high rpm's no power.
Old Aug 19, 2007 | 11:00 PM
acedraven's Avatar
Default Idle not adjusting, high rpm's no power.
Im looking for any information as to what could cause these problems, maybe something related that could cause them? Ill try to explain things as best i could. First off the car is a 1994 LT1, its got about 175k on it atm. I bought the car about 8-9 months ago the owner had new wires, new opti unit and i believe a new ecm put in a few months before the purchase. I changed the oil, flushed the radiator, checked/toped off fluids put new plugs in and lubed the joints (basic maintaince stuff). The car has been a daily driver since and i have had no problems with it. A few weeks ago, the car started becoming hard to start at times, (sometimes i could just jump in and itd start right up no problem, and sometimes it would take a few cranks). Beyond that the car drove perfect. At idle the rpms would also jump to about 1500 or so and then it would adjust itsself at the 800 or so mark, Ive read that this is pretty normal because the idle speed is adjusted by the ecm. Well the past week or so sometimes the rpm's will just not drop. Ive even had the car start and idle at 2k and not drop down. on top of this two days ago while driving the car seemed to lose power, rpms would shoot up to about 4k or so and it would just be kinda coasting along and not be pulling as it should. I pulled a few plugs and they seemed fine, wires are ok, and are nice and tight. I have the following codes, 4. H29 H22, 9 H64. The air pump has not been working since purchase because of a burnt relay. Also about a week or so ago the Service ASR light came on. Please just give me some ideas on what to look at [:-] , Ive been checking numerious things such as the iac vavle..etc but I dont want to say that i have definantly ruled anything out. Thanks for your time and the info. - phillip
O4XC5
Feb 23, 2008 09:08 PM
Zanador
May 28, 2007 09:10 PM
mthanson
May 27, 2007 07:47 AM
Curious George
Jan 1, 2007 11:38 AM
Jonmikes
Dec 30, 2006 01:18 AM
