L98 Problem
Old Aug 27, 2006 | 07:11 PM
tvfoxdude's Avatar
Default L98 Problem
Hi ya'll, I hope someone can help me,, and I havent found an answer in past posts, I have a '86 L98, one it runs hot, hopefully I can figure that out on my own. The other problem is when I run it in the garage, the fuel fumes are so bad you cant stand it, it just smells like its running really rich. One guy told me that a clogged cat would dmake it smell like that, today I diconnected my exhaust from the headers, and it still smells bad. Idle is fine, rev's are fine, no SES light, it just stinks to high heaven..pls. help
Old Aug 27, 2006 | 07:32 PM
Default RE: L98 Problem
Is it black smoking? Check your fuel pressure, also check fuel pressure regulator vacuum hose for fuel in it, that will make it run rich. No fuel leaks on intake or fuel system? Those are things to check first. [8D]
Old Aug 27, 2006 | 07:38 PM
tvfoxdude's Avatar
Wow thanks for the quick reply,,,,theres no smoke what so ever, no fuel leaks anywhere that I can see. Where is the fuel pressure regulator at? Sorry I'm used to an engine that if it had compression, fuel,and spark, it ran.
Old Aug 27, 2006 | 10:45 PM
Red89vette's Avatar
Are there any mods on the car? if so what are they; that would also help in determining a problem. If its stock check the spark plugs to see if they are fouling, from there I would check fuel pressure, then for vaccume leaks, last but not least I would check cap rotor plug wires. Also check you o2 censor they might be slightly fouled causing a rich condition without throwing a code or CEL.
Old Aug 28, 2006 | 03:14 AM
raisinbran's Avatar
how does the car perform?
Old Aug 28, 2006 | 09:51 AM
Fuel pressure regulator is on the fuel rail on the passenger side of the engine. It is about 2" in diameter and has a vacuum hose attached to it. [8D]
BADDUCK
May 31, 2006 10:09 AM
89rdstr
May 17, 2006 12:43 AM
sledog
Dec 1, 2005 04:21 PM
trailcj7
Sep 11, 2005 04:45 PM
poxic
Jul 24, 2005 01:58 PM
