Leak issue
Old Sep 29, 2007 | 06:38 AM
  #11
SC300TURBO's Avatar
Default RE: Leak issue
could you give me an idea of where to look for that?..is in inside or underneath the car?
thanks
Jeff
Old Sep 29, 2007 | 07:32 AM
  #12
rshiver's Avatar
Hi SC,... the drain, I would assume would be under the condenser housing on the fire wall under the hood on the passenger side. I took a look at mine and I couldn't get my hand under it to feel for it. Would probably have to get to it from under the car.
Old Jun 13, 2017 | 05:19 PM
  #13
lostsoul1975's Avatar
Default c4 water leak
I have 1995 c4 convertible and have been fighting a water leak. pulled carpet out new is on order! leak come from behind dash. used seem sealer where I thought needed it and windshield is getting replaced thursday. I also made sure all drain tubes were unclogged. any help would be great thanks new member
Old Jun 14, 2017 | 09:20 PM
  #14
Does it still leak after all of your fixes?
Old Jun 16, 2017 | 08:11 AM
  #15
hcbph's Avatar
Is it water or could it be coolant? Many have had a header core fail causing leakage into the drivers compartment. One way to test that is turn the heat on and use a cooling system tester and pressurize the cooling system and see if it hold pressure or not. If not, you might be able to hear it leaking. From what I've read (never having done itself) it's either easy or a bear to change out a heater core (depending on who you listen to).
Old Jun 16, 2017 | 03:53 PM
  #16
Default leak issue
It's not coolant, car has been sitting for a month and leaking rain water. windshield replacement got move to tomorrow at 8am so I will keep you updated! The seam sealing i have done has not corrected the leak. Once windhield is done i will do a test then install my new weather stripping which is in the mail. Thanks for the reply, Always loved the c4 so just pumped to get her back where she should be. 56,000 miles
dph
Feb 12, 2006 11:57 PM
dcd58
Nov 12, 2005 09:22 AM
dcd58
Nov 10, 2005 08:49 PM
mazie
Oct 3, 2005 12:32 AM
bilt5
Sep 5, 2005 05:47 PM
