More 4+3 issues
Old Oct 10, 2007 | 10:48 AM
Blue86vette's Avatar
Default More 4+3 issues
Here's a puzzler for you experts out there. I have an 86 w/ the doug nash 4+3. Usually it will engage OD normally. Ie. I shift through the gears and when I let off the clutch the OD will engage. No problems right...wrong. If I rev hard through first hear the OD shuts off as normal but will not re-engage unless i park and turn off the car for about a minute. After that it works fine again. Unless I get on it in first again.
Old Oct 10, 2007 | 10:58 AM
rshiver's Avatar
Default RE: More 4+3 issues
Hi Blue,...Experts you say?? Well that leaves me out.
I assume the ECM controls the OD, You might try disconnecting the battery for a little while to reset the ECM,.You might also check the connection on the temp sensor we were talking about in the other thread, the one on the front of the motor above the water pump.
Old Oct 10, 2007 | 01:43 PM
Thanks for the reply. I did actually try the battery trick. Although it was by accident. Alternator died on me. It runs better after the reset but from time to time i still get the od problem.
Old Oct 10, 2007 | 02:27 PM
rshiver's Avatar
Blue, here's some info on the 4+3, seems there is a overdrive relay somewhere, and theres aswitch located on the OD unit.
http://www.5speeds.com/archive/27.html
Old Oct 10, 2007 | 04:18 PM
Awesome info. I found that after kicking down in first gear the OD is supposed to stay off until reaching fourth gear. Kicks down as advertised but does not re engage the OD in fourth. I think i may need a new ECM.
Old Oct 10, 2007 | 04:39 PM
rshiver's Avatar
Hi Blue, I would exhaust all other options before buying a new ecm. My 85has an auto, so I don't know where all the components areyou need to check. Some one will come along that knows more about them.
Be sure to check out Crash's post in this thread.
https://www.corvetteforums.com/m_44272/mpage_2/tm.htm
Old Oct 11, 2007 | 10:24 PM
86 Ironhead's Avatar
I've heard the ECM computer chipcan be programed to shutoff the overdrive in different configurations. You might want to remove the chip and get it read. Mine has the 180 degree theromstat/fan Upgrade. Not sure how the overdrive is programed. Mine is also a 4+3.
zo6r black widow
Nov 30, 2005 11:31 PM
bobashton
Oct 27, 2005 03:43 PM
crvttbass
Sep 22, 2005 02:19 PM
zzz06r
Sep 1, 2005 12:08 PM
kittysvette
Jul 27, 2005 07:32 PM
