movin' on here...
ORIGINAL: LeesVette
Yep but not out through the side marker light.
https://www.corvetteforums.com/m_421..._1/key_/tm.htm
Maybe you're thinkin' Ishould put the lens back in tho', before workin' on the antennae?
Anyway, for those of you who might find a little help in a pic or two, here's more... And if you been here before (and can help), bring it!
[IMG]local://upfiles/5243/96AA3C94E4AA48269CE53C0EA78CCFD0.jpg[/IMG]
[IMG]local://upfiles/5243/C0C23DDEC3C84A798A3541A8225F5F81.jpg[/IMG]
ORIGINAL: LeesVette
Looks like a bad call anyway there. I'm gonna' work them bolts through the side marker light.
Unless ya' stillthink I should put it backsince finishin' the side marker work...
Those are two connectors at the top of the motor assembly, for those of you who've not been there yet... I think if you gotta' do antennae work, it is definitely a good idea to pull the side marker lights!
[IMG]local://upfiles/5243/FBBCE5CACABA4E488C44211432F011EE.jpg[/IMG]
Don't lose track of your grounding washers...
These two were on the same bolt. I tagged 'em with a breadbag tie...
Clean 'em well at re-assembly, for good contact. Might wanna' use dielectric grease (the mustard stuff from the other thread).
[IMG]local://upfiles/5243/AF0D5055CEE84653B2A99DB2B3BDD1C1.jpg[/IMG]
Need real help here...
How does this guy disconnect? It's the one that goes back to the left, and then up, in the pic. Looks like the antennae signal cable itself.
[IMG]local://upfiles/5243/D11410395200487B92417E5960C3C340.jpg[/IMG]
[IMG]local://upfiles/5243/58B70463E32C4F31A0567D0CC3FC1459.jpg[/IMG]
ORIGINAL: LeesVette
ORIGINAL: LeesVette
I have an aftermarket stereo but mine does not do that. My antennae motor is shot and does not go up but I get great reception with out. I like the looks of it better with the thing down anyway.
ORIGINAL: cwb
Another pic of this wire...
How DOES it disconnect???
[IMG]local://upfiles/5243/3C66AB70E716420588F62F7C504EC8E2.jpg[/IMG]
Has anybody ever disassembled one?
It doesn't just pull out? I've never done one before, but here are some step by step instructions..
http://content.madirect.com/pdf/601246.pdf
