myinterior lamp delay relay
Old Sep 30, 2008 | 08:34 PM
me2's Avatar
me2
Default myinterior lamp delay relay
My C4 corvette has a internal lamp problem.
They wil not turn off.The dash does not show any
open doors.I think it is the time delay relay.I purched
one, but can't find it on the car Will someone help Me?
Old Oct 1, 2008 | 11:37 AM
Default RE: myinterior lamp delay relay
Welcome to the boards there...
What year is your car? The timer module might or might not be the problem. What did you to to test the old one?
Old Oct 13, 2008 | 08:54 AM
CorvetteArchives's Avatar
I'm assuming its an 84-89? I think the computer controls the delay after that year.
It should be under the passenger side kick panel. Since you have one you at least know what it looks like so that should make it easier!
Many times the door jam light switch needs a cleaning ora shim(washer behind it) despite any indicators.
A good way to check before buying a new one (for anyone else reading this) is to jump the wires in the harness with timer removed and see if the light goes off when doors are shut. They are the 2 white wires. There is one on the end of the plug and one second from the end.
Catman87
Mar 23, 2008 02:15 PM
DeeVeeEight
Feb 15, 2008 12:08 PM
Hopper
Jun 4, 2007 10:30 PM
jadrfld
Feb 25, 2006 06:17 PM
sbennett
Dec 20, 2005 10:18 PM
