NoGo
Old Sep 27, 2024 | 10:34 AM
7DaySat7's Avatar
Default NoGo
1996 Corvette C4 automatic, ASR problem, accelerator pedal will not accelerate engine, cable good, ASR cable from ASR to throttle body not moving throttle body, throttle body will accelerate engine manually, ASR light on, don't have access to read codes, any ideas, in Wellington, Fl.
Old Sep 27, 2024 | 06:12 PM
74HARLEY's Avatar
Well, there is no "one and done" with computer systems. You can get a decent code reader under 50.00. Or you may be able to rent one from your local parts store. It's really the best way to go.
Old Sep 27, 2024 | 08:24 PM
Welcome to the forums. Heard of a guy awhile back with the same issue with the ASR light on his 94 not sure if yours is the same. His problem was back by the left rear wheel with a bad power wire to the ASR ABS system. The throttle may have a bad cable, or the throttle pedal may be hanging up or both.
Old Sep 27, 2024 | 10:12 PM
7DaySat7's Avatar
Default NoGo
Just ordered the factory shop manuals, not too familiar with code tracing, kind of old school, (my other Vette is a 63 SW), thanks.
this is actually the 1st issue I had with the 96, thanks.
Old Oct 16, 2024 | 09:57 PM
It might be easier to learn French than trying to figure out shop manuals.
Old Oct 16, 2024 | 10:14 PM
There is a related thread below this posting that might be helpful.
Old Oct 17, 2024 | 10:13 PM
Welcome to the forum. Most auto parts stores will read your codes for free.
Old Oct 21, 2024 | 12:04 PM
7DaySat7's Avatar
Default ASR issue, throttle in-op
Got the manual, you're right, very hard to follow. My problem is the car has no throttle response, only idle, ASR throttle cable not broken but not advancing throttle body linkage so can't drive it. Tried everything, going to tow it to Eismann Corvette Jupiter FL on Wed. Unless anyone has come across this issue.
dnovak1968
Mar 13, 2019 01:58 AM
Curly
Jul 19, 2009 12:18 PM
Curly
Jul 19, 2009 12:17 PM
dburke
Jul 21, 2007 07:18 PM
ThrottleJunkie
Sep 19, 2006 09:43 PM
