ASR on my '93
Old Jul 21, 2007 | 07:50 AM
dburke's Avatar
Default ASR on my '93
Does anyone know how to adjust the anti-slip recovery on my '93 OR
The max voltage that I can get out of my TPS (new one) is 3.05 volts at WOT (closed is 0.65volts). At 3.05 volts the throttle plates are less then half way open.I can't account for this withcable stretch, etc. (at least sofar - I headed back out to the garage is a few minutes). I suspecting that the ASR may wacked (altho' it works just fine). Problem is I really don'tknow what isdoing with the throttle cable. How does it work?Has adjustment have anything to do with thethrottle cable? .......????
Thanks,
Dan
Next time I will go to the garage before I write: to adjust the throttle cable, push the button on the cable connetor and pull the cable tight.
sorry
Old Jul 21, 2007 | 11:26 AM
Default RE: ASR on my '93
ORIGINAL: dburke
Thanks,
Dan
sorry
Doesn't max voltage come in long before WOT??? I think I've read that WOT is 3/8 open, and further...
Old Jul 21, 2007 | 12:04 PM
dburke's Avatar
,,but the throttle cable was so out of adjustment that Icould not obtain WOT.And you have to get more then 3 volts or you won't get all of your fuel either. Now it reaches about 4.2 volts (you onlyneed 3.75 for all the fuel) and, yes long before WOT. At least according to the TurboLink software that is taking the measurement.
Thanks
Old Jul 21, 2007 | 01:23 PM
ORIGINAL: dburke
Thanks
10-4 on the cable adjust...
Where did you get your scan link hardware/software? How much? Usin' a laptop? What OS? Can you post screenshots of the app?
Thanks...
Old Jul 21, 2007 | 07:18 PM
LeesVette's Avatar
Its calledAcceleration Slip Regulation.
brucep505
Aug 30, 2008 07:10 PM
95trplblkandtan
Aug 17, 2008 10:33 PM
txcwi
May 18, 2008 08:33 AM
RobertAz2005
May 25, 2006 04:08 PM
okvette92
May 9, 2006 01:04 AM
