Option codes
Old Aug 20, 2006 | 02:10 PM
redvet's Avatar
Default Option codes
I have been able to decipher (with help from this forum) most of the option codes listed on the console lid of my 92. Does anyone know where I can find a complete list of the options for that year? I have about 8 codes listed that were not on the list provided in the earlier forum. Again, thanks for all the help. This forum really rocks!
WAVE[&:][&:]
Old Aug 20, 2006 | 02:54 PM
LeesVette's Avatar
Default RE: Option codes
Here is a complete a list as I can find:
The list:
1YY07 - Base Coupe
1YY67 - Base Convertible
1AZ - Modification stock order or order sold
1SB - Marketed option package 2
24S - "Removable Roof Panel, blue tint"
64S - "Removable Roof Panel, bronze tint"
AC1 - Power Passenger Seat
AC3 - Power Driver Seat
AJ3 - S.I.R. system (driver side only) 90-93
AK5 - Front seat S.I.R. system (driver & pass.) 94-96
AQ9 - Leather Sport Seats
AR9 - Base Leather Seats
AU3 - Power Door Lock System
B2K - Callaway Twin Turbo Engine (on Bowling Green Twin Turbos)
B4P - Fan, Aux Cooling, Electric
BGR - Bowling Green assembly plant
C05 - convertible folding top
C2L - Dual Removable Roof Panels
C49 - Electronic Rear Window Defogger
C60 - Manual Air Conditioning Controls
C68 - Electronic Climate Control
CC2 - Auxiliary Hardtop (convertible only)
CC3 - Removable Plastic Roof Panel
CF7 - Removable Roof Panel (Solid Body Color)
D3X - Speedometer Driven Gear (25513049)
D4L - Speedometer Driven Gear (25513050)
D7B - Speedometer Driven Gear (25513043)
D7C - Speedometer Driven Gear (25513045)
D8E - Vehicle Speed Sensor (10456021)
D8F - Vehicle Speed Sensor (10456022)
D8H - Vehicle Speed Sensor (10456039)
DC7 - Electronic LH & RH Outside Mirrors
DC8 - Electronic LH & RH Outside Mirrors
DL5 - roadside service information decal
DL8 - LH/RH Heated Sport Mirrors
E5C - Delete speedometer adaptor
E9Z - Delete speedometer key
EXP - Export
F45 - Adjustable Suspension
FE1 - Base suspension
FE3 - sport suspension (96 Z51)
FE7 - Heavy Duty Suspension
FE9 - federal emissions
FX3 - Adjustable Suspension
G44 - 3.07 Rear Axle Ratio
G87 - ring gear 8.50 inch
G92 - Performance Axle Ratio
GHO - 3.54 axle ratio
GM1 - 2.59 Rear Axle Ratio
GM3 - 3.45 Rear Axle Ratio (8.5 in. Ring Gear)
GT7 - 3.33 rear axle ratio
GU2 - 2.73 Rear Axle Ratio
IP3 - Interior trim design P3
J55 - Heavy Duty Brakes
JL9 - Antilock Front and Rear Disc Brakes
K05 - Engine Block Heater (Canada Export only)
KC4 - oil cooler
KG9 - 140 amp generator
KW2 - 124-Amp Generator
L83 - 1984, standard engine, Crossfire, 350ci, 205 hp.
L98 - 1985-1991, standard engine, 350ci, 230~250hp.
LT1 - 1992-1996, standard engine, 350ci, 300 hp.
LT4 - 1996, optional engine, available only with manual transmission, 330hp
LT5 - 1990-1995, optional engine, part of ZR1 package, 375hp, in 1993, upped to 405hp.
MD8 - 4-Spd. 4L60 Automatic Transmission
ML9 - manual 6-speed, ZF-transmission
MN6 - 6-speed manual transmission
MX0 - automatic transmission
NA5 - Federal Emission systems
NK4 - Sport Leather Steering Wheel
NN5 - California Emission Requirements
QA1 - Wheel, 17 x 9.5, Aluminum
QA2 - Wheels, 17 x 9.5 (Front) 17 x 11 (Rear), Aluminum
QB6 - aluminum wheels 17 x 8.5" front, 17 x 9.5" rear
R9Z - Control sales item 100
T61 - Daytime Running Lights
U19 - Miles & Kilometers Dash Cluster
U1F - Delco Bose Stereo System w/ CD
U52 - Electronic Instrument Cluster
U75 - Power Antenna
UJ6 - Low Tire Pressure Warning System
UM6 - "Bose Stereo w/ CD & Cassette, Seek/Scan, Clock, ETR Radio"
UU8 - Delco Bose Stereo System
UXO - Dual Floor Sill & Extended Range Speaker System
VM3 - information label, bumper impact standards
V56 - Luggage Rack (convertible only)
V73 - Vehicle statement, US or Canada
XAA - front tire P255/45 ZR17
XAU - Front Tire, P275/40ZR17
YAA - rear tire P285/40 ZR17
YAU - Rear Tire, P275/40ZR17
YBE - Rear Tire, P315/35ZR17
Z07 - Handling suspension
Z51 - Handling suspension
Z52 - Handling suspension
Z5G - Identification, Callaway Orders (not listed on SPI label all years)
ZR1 - Special Performance Pkg.
Colour codes:
Exterior
10U - Arctic White exterior
Interior
70I - Torch Red interior
703 - Torch Red leather
Rear Differentials
This topic gets picked on quite frequently. Time to clarify it. There are two differentials, the D44 and the D36 (not RPO codes), both made by Dana. The D36 is standard on the automatic and the D44 is standard on the manual, expection being 1984, when the D36 was the only one available.
These are the codes related to the rear gearing, with the differential that they use:
G44 - 3.07 Rear Axle Ratio - D36, optional; D44, standard, pre-1992.
G92 - Performance Axle Ratio - Shows performance axle selected.
GHO - 3.54 axle ratio - D44 only.
GM1 - 2.59 Rear Axle Ratio - D36 only.
GM3 - 3.45 Rear Axle Ratio - D44 only.
GU2 - 2.73 Rear Axle Ratio - D36 only.
What this means is this, G92 is not dependant on a specific ratio or differential housing. It's just an indicator, a rather redundant one when you think about it.
There is a D44 offered with a 3.33 or 3.31, don't have that RPO yet
Old Aug 20, 2006 | 03:10 PM
redvet's Avatar
I appreciate the info Lee. That is the same list I have, so may have to contact a dealer (ugh!)for help. And thanks again!
Old Aug 21, 2006 | 11:18 AM
LeesVette's Avatar
You can get a build sheet here:
https://store.corvettemuseum.com/ser...buildsheet.asp
Maybe that can help you.
stonecoldsaysto
Jul 30, 2017 12:36 AM
garari
Aug 10, 2006 01:16 AM
Travis
May 3, 2006 03:02 PM
pierceman
Jan 7, 2006 12:42 AM
spyder02
Dec 10, 2005 02:44 PM
