Power antenna relay
Old Sep 27, 2021 | 05:01 PM
Roger Freeman's Avatar
Default Power antenna relay
The power antenna relay was disconnected without making sure which way the relay was plugged in is there a way that is supposed to be plugged in or is it okay to plug in either side into the relay and be okay I have a 1990 C4 I don't know if the relay went bad so I ordered a new one but the plug was pulled out on both sides and I don't know which way plugs back in or does it matter
Old Sep 28, 2021 | 06:59 PM
A relay typically has four wires. Two wires are for power and ground and the other two are for the contacts. So you need to determine if that is the case and if so, determine which connector has 12 volts and ground on it. Then you need to determine which pins on the relay are to the coil and which two are to the contacts.
​​​​​​ You will just need a simple VOM to do this.
Roger Freeman
Sep 28, 2021 07:15 PM
harey1
Apr 3, 2008 11:42 PM
wildfire
Feb 24, 2008 04:18 PM
supermano57
Nov 16, 2005 07:11 PM
jafone
Jul 19, 2005 03:24 PM
