Springs.
Old Sep 23, 2006 | 11:09 AM
94blackC4's Avatar
Default Springs.
Anyone know where i can get some srpings for my car? I want to lower it and i dont want to cut my own springs. I would rather have soemthing that was professionally done. Thanks guys
Old Oct 10, 2006 | 04:24 PM
TopSpeed's Avatar
Default RE: Springs.
I've used Eibach springs on other cars I've owned, with fantastic results...
Eibach Springs
Holy Toledo... I just checked their site and can't find any parts listings for Vette's!!!! Now, THAT'S whacky! Sorry, bro, I am at a loss here for you now....
Old Oct 10, 2006 | 11:19 PM
Curious George's Avatar
It may be difficult to do what you are asking on the C4 body / frame. The C4 uses a fiberglass single "leaf" spring in lieu of normal springs. Check into the suspension and you will see what you are up against.
Old Oct 11, 2006 | 12:39 AM
Really on the composite springs in your C4, it tells you not even scratch the spring because it will weaken it. [] I ordered a front spring from Ecker's this week because my front spring is sagging. I can barely put 1 finger between the tire and the hood an you are supposed to be able to put your hand in there. The weak spring has already broken my air dam in front just by hitting bumps in the road and inclined driveways. You really need that air dam to help keep the engine cool. I'll probably be putting the spring in this weekend. [8D]
Old Oct 11, 2006 | 04:06 AM
thespannerboys's Avatar
I agree that front air dam is Key, I took mine off to replace it, it was in rather bad shape ( drive ways, speed bumps and such ), I drove down to get some supplies with out the air dam, and the temp was up at least 25deg, and it took ALOT longer for the temp to lower was I got moving!
Old Oct 12, 2006 | 02:39 PM
TopSpeed's Avatar
ORIGINAL: Curious George
*smacks forehead* Of course!! Oh boy, do I feel stupid.....[sm=headbang.gif]
[sm=pcwhack.gif]
ksvette
Oct 15, 2007 09:39 AM
tankerpilot01
Sep 13, 2007 08:07 PM
nosty1
May 7, 2007 01:22 PM
jjz28
May 5, 2007 05:40 PM
sd951
Apr 10, 2007 03:21 PM
