Temp sensors/sending units
Old Oct 30, 2007 | 01:51 PM
Eggster's Avatar
Default Temp sensors/sending units
Where are these located on an LT1 engine?(assuming it's the same for all LT1s from '92-'96). I know one is located on the water pump, a screw in type. It was tested and is working properly.
I need to find the other(s) because my gauges are still having trouble. The needle temp gauge shows I'm overheating big time, but the digital one seems normal. I don't think an air bubble in the cooling system could do this.
BTW, a few months back I posted about my problems with the opti/ignition/rough idling. All of that has been fixed with the following replacements: Spark plugs and wires, new vented MSD Optispark distributor, new water pump, and all-weather wiring connectors. If I can fix this temp gauge issue, this thing will be 100%.
Old Nov 1, 2007 | 11:25 AM
Ric's Avatar
Ric
Default RE: Temp sensors/sending units
Hi Eggster
There is another temp sending unit on the LT1 between the 6&8 spark plugs on the right head. I think this is the temp Gage sending unit. I think the digital gage works from the ecm of the temp unit on the water pump and the sending unit between 6&8 spark plug would be the dial Gage. Hope this helps some.
Ric W
Old Nov 1, 2007 | 02:27 PM
Eggster's Avatar
Thanks Ric. I'll update after it's replaced this weekend.
KenHorse
May 15, 2007 08:07 PM
racerrick
Jan 4, 2007 09:39 AM
littleRedCoupe
Oct 16, 2006 09:35 AM
FLbTLINE
Sep 10, 2005 01:22 AM
espo 89
Jun 13, 2005 08:48 PM
