trouble with cooling fans
Old Mar 3, 2008 | 01:26 PM
dr_maddox's Avatar
Default trouble with cooling fans
I have a 1990 that is wanting to overheat if it is left idling for a short while because neither of the cooling fans are kicking on at all. What would be the main cause for this? fan motor, relay, etc.
Old Mar 3, 2008 | 02:09 PM
YANKEECORVETTE's Avatar
Default RE: trouble with cooling fans
How hot? One fan comes on around 226F and both when the a/c is on. Check the related threads this subject comes up often. These engines like to run hot and many people get nervous about it . If the temp. goes over 235F its time to break out the volt meter.Bad motor or temp. sensor Good luck.
dr_maddox
Mar 3, 2008 05:06 PM
toby11
Nov 21, 2007 02:53 AM
texvette
Jan 6, 2007 05:46 PM
texvette
Jan 6, 2007 01:31 AM
patches96
Oct 10, 2006 04:40 PM
