cooling fans
Old Jan 5, 2007 | 09:20 PM
texvette's Avatar
Default cooling fans
Hey All,
I have a 2000 C5, regarding the dual fans on the radiator, shouldnt one fan be on all the time? Both fans come on when I click onthe a/c but as soon as i turn off the a/c both fans turn off. I checked the fuses, all ok. Even when the twmp gets to 225 they still dont turn on by themselves unless i click on the a/c.
Any ideas????
Thanks
Old Jan 6, 2007 | 05:46 PM
Dave01's Avatar
Default RE: cooling fans
From my archives:
"Factory fan setting for an 04 are as follows:
The low speed cooling fans are commanded on when the coolant temperature reaches 108°C (226°F). They are turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fans are commanded on when the coolant temperature reaches 113°C (235°F). they are turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fans will be turned on at vehicle speeds less than 56 kPh (35 mph)."
Dave
dr_maddox
Mar 3, 2008 05:06 PM
dr_maddox
Mar 3, 2008 02:09 PM
toby11
Nov 21, 2007 02:53 AM
texvette
Jan 6, 2007 01:31 AM
patches96
Oct 10, 2006 04:40 PM
