vent problem? Need help
Old Nov 15, 2007 | 10:29 AM
morgans762's Avatar
Default vent problem? Need help
I have a non climate controlled c4. With the ac/heat in the off position I get outside air blowing out from the under dash vents. Also myblower motor switch is not working all of the time. Any help would be greatly appreciated.
Old Nov 15, 2007 | 08:32 PM
Default RE: vent problem? Need help
Is the air coming in all the time or just running down the road? What year is your car?
Old Nov 16, 2007 | 08:40 AM
morgans762's Avatar
Just when running down the road. Car is 84.
Old Nov 16, 2007 | 10:54 AM
9340Vette's Avatar
If you have a Max or recirulation button, then drive while this button is selected if you don't want outside air coming in. The direct air which the button looks like an arrow going straight through the car is if you want outside air to flow. I hope this is not too confusing. It is best to drive around with the max or recirculation button selected so you don't get outside pollution and fumes from other vehicles. Just crack your windows every now and then to get some fresh air when not behind other vehicles. BK
Old Nov 16, 2007 | 05:41 PM
Early model GM's ran the blower on low even if the switch was turned off for fresh air ventilation. I know the trucks did and I think the 84 does to.
Old Nov 17, 2007 | 08:55 AM
morgans762's Avatar
I dont see any fresh air button on these controls. All I have is a dial for fan speed and two sliders . The upper for heat/ac/vent , the lower for temp control. Any suggestions?
Old Nov 17, 2007 | 11:06 AM
9340Vette's Avatar
Could you send a pic to me? BK
Old Nov 17, 2007 | 11:25 AM
When you turn the key on with the controls off, do you hear blower motor on low speed?
Old Nov 26, 2007 | 02:50 PM
morgans762's Avatar
With controls off, blower motor does not turn. Is there a external air valve for inducting fresh air. Its my guess that its stuck open, or the whole temperature switch array is bad?
Old Nov 27, 2007 | 09:17 PM
My guess is the mode switch cable is either broken or out of adjustment. The controls on your a/c is all mechanical and vacuum controlled. Blower switch being intermittant, I would say bad connection at the blower motor (power and ground), or at the the blower resistor or switch.
