vent problem? Need help
I have a non climate controlled c4. With the ac/heat in the off position I get outside air blowing out from the under dash vents. Also myblower motor switch is not working all of the time. Any help would be greatly appreciated.
If you have a Max or recirulation button, then drive while this button is selected if you don't want outside air coming in. The direct air which the button looks like an arrow going straight through the car is if you want outside air to flow. I hope this is not too confusing. It is best to drive around with the max or recirculation button selected so you don't get outside pollution and fumes from other vehicles. Just crack your windows every now and then to get some fresh air when not behind other vehicles. BK
My guess is the mode switch cable is either broken or out of adjustment. The controls on your a/c is all mechanical and vacuum controlled. Blower switch being intermittant, I would say bad connection at the blower motor (power and ground), or at the the blower resistor or switch.
