Window motor quiestion
Old Dec 23, 2007 | 10:27 AM
Barry11's Avatar
Default Window motor quiestion
This window motor is from ecklers. Is it reliable and worth replacing the old factory one? No, I don't want to upgrade to the later styles. Just want to replace the motor. Also, going to work with a new ribbon as well.
http://www.ecklers.com/product.asp?p...p;dept_id=1673-Window Motor.
Second. Headlight Bushings. I have searched Ecklers and they only sell them for88 and up. Will these fit? I have a powdery dust on one side and the headlight will go down but will not go up.
http://www.ecklers.com/product.asp?p...p;dept_id=1476
T.I.A.
Old Dec 23, 2007 | 11:59 AM
rshiver's Avatar
Default RE: Window motor quiestion
The window motor should be fine, I bought one three years ago, haven't had any problems with it.
As for the bushings,Are youtalking about bushings that theheadlight assembly pivots on?The ones you're looking atare delrin bushings.They goinside the gear housing assembly on 88 and up, they won't work on pre 88.
On the headlight that won't go up, do you hear any noise? If you do, the gears may be stripped, which is just a matter of replacing the gears. If you don't hear any noise, you probably have a bad headlight relay.
Old Dec 24, 2007 | 07:37 AM
You ought to convert the ribbon type regulator to the gear and lever type that was used in late 86 and up. There are instructions somewhere in these forums about the conversion. I did mine and it works SO much better and faster.
Old Dec 24, 2007 | 07:42 AM
Here's a thread with some explainations although no pics. Do a web search for it as I think the other Corvette forum might have some pics.
https://www.corvetteforums.com/m_18301/tm.htm
Old Dec 24, 2007 | 12:18 PM
Barry11's Avatar
Thanks to you both. Do you have a price estimate for the whole assembly? I like the 50 dollar route myself but...
Old Dec 25, 2007 | 11:10 AM
It was about 200.00 a side.
Old Dec 28, 2007 | 08:31 AM
Barry11's Avatar
Ill fix the ribbon for now so the window will work and then do one side at a time. Do you know where I can get the whole assembly? Ecklers sells motors...which is what I saw but that is for the earlier models. While I am in there, I need to tight then the windows unless it is because the seals (inner/outer) are worn so bad.Always costing money.
Old Dec 29, 2007 | 06:08 AM
I bought mine through the dealership, but I get them @ dealer cost because of my auto repair shop. G/L [8D]
ZR1clone
Sep 17, 2008 10:14 AM
95vettetx
Feb 24, 2008 11:09 AM
Barry11
Feb 1, 2008 11:49 AM
jns1708
Apr 18, 2007 09:56 AM
Hawaiian Punch
Nov 1, 2005 06:24 AM
