Wiring Diagram. .
Old May 14, 2008 | 03:34 PM
avp0713's Avatar
Default Wiring Diagram. .
Okay. . .
My 1985 Greenwood (posing in driveway for the last 8 years ...immovable) is getting to its finishing stages of engine install/rebuild, as a project for the students. Its free (albeit novice) labor for me and a learning experience for the students; The teacher is a "master mechanic". The engine is in, all new parts; ceramic headers, distributor cap, wires, plugs, boots, valve covers, breathers, coolant hoses, heater hoses, trans cooling lines (braided), timing chain and cover, brake systems.
This is not a full rebuild as the teacher was hesitant to get into polishing the bores, replacing valves etc.
Here is some text from the teacher in his last email to me: "....The wiring for the engine management system is a mess, wires are missing and taped together wrong, we tried to trace down what we could but that is over the capabilites of the students."
Is there an Engine Wiring Diagram that I can get for the 1985 Corvette (automatic)?
Everything was working electrically when I towed the car to their garage; perhaps they should have taken pictures before dismantling/disconnecting.
School is ending in a few weeks, the car cannot sit there over the summer, and the whole idea was to be able to DRIVE the car home.
Thanks All. . .
Old May 14, 2008 | 08:08 PM
Default RE: Wiring Diagram. .
What engine is in the '85 ? I have the factory shop manual for my '87 on this computer and may be able to email the wireing diagrams to you if they are in there?? and the carshave the same engine. My '87 is TPI L98 350 with auto trans. Cheers
Old May 14, 2008 | 10:13 PM
avp0713's Avatar
Blueshark
I too have the 1985 L98 tpi 350 engine with automatic trans.
If you could email those diagrams to me (avp0713@comcast.net) I would be forever thankful;
What I inferred but didn't clearly mention is that I'm having all this work done at the local High School. They took on the project so its free; I only need to supply the needed parts.
Tony
Brick, NJ
avp0713@comcast.net
kiwi
Technical Diagram Help
Nov 6, 2008 11:50 PM
mhowald
Jun 11, 2007 03:58 PM
robboyce
Jun 1, 2007 05:37 AM
camaro6668
Mar 15, 2007 09:36 PM
Dans endless project
Apr 9, 2006 07:39 PM
