99 Keeps forgetting the Key FOB
Old May 10, 2009 | 07:42 PM
mxracer_6's Avatar
Default 99 Keeps forgetting the Key FOB
Has anyone had and fixed a problem with the car's system forgetting the Key FOB? I put a new battery in the car a month ago. Shortly after I started having the problem. I put a new battery in the key FOB a week ago since the problem started. It will work fine for a few minutes or a few days before communication with the FOB stops. I retrain the car and it works for a while again. Anyone have any thoughts on how to stop this from happening?
Old Sep 19, 2009 | 10:06 PM
jbihl's Avatar
Default Same Problem With a 2000
I have the same problem with a 2000. Did you find a fix?
jbihlnc@bellsouth.net
Old Oct 13, 2009 | 11:19 PM
gmichaelc's Avatar
Cool fob problems
I have the same problem with my 99
I think it is related to the fact that my TPMS in the wheels ar on there last legs.
My plan was to upgrade to a 2001 system because of costs.
the other options is that possibly the reciever is not grounded in some way or a bad connection. I had problems when I would back out of the shop and turn hard left. I would get a tire speed issue, can't remember what it was now but if I shut down and restarted it went away. I fixed that by removing the wheels and disconnectiong the wheel sensors. Spraying them wiht WD40 and blow dry both connections. I then used dielectic grease on the connection. I for the life of me make the fault come back. Electrical connection seem to be pretty important.
Old Oct 29, 2009 | 04:07 AM
cherry2's Avatar
what do you mean by FOB....i dont know what do you mean by FOB...........
jbihl
Sep 19, 2009 09:41 PM
firemanbm
Jun 10, 2009 06:43 PM
1red93
Feb 1, 2008 05:04 PM
byedan1
Aug 20, 2006 01:45 PM
jdavis
Jul 17, 2005 03:31 PM
