Brake replacement guidance
Old Jun 24, 2006 | 03:01 PM
Mudwrestler's Avatar
Default Brake replacement guidance
I recently bought a 2001 C5. My first Corvette. I want to replace the pads and rotors on all four corners. I've done it on other cars, but it's always a new experience. When I look at how to jack the car up per the owners manual.....it looks like the jack point is almost in the longitudinal center of the car?. How do I get the jack in there??????
Also....I understand that the rotors are easy.....just take out two bolts and remove the caliper, then the rotor just slips off the studs.
But, do I have to disassemble the caliper to get the new pads in??????
I've tried to get a Haynes or Chilton manual for guidance, but it seems the most recent edition they have for Corvettes stops with the C4.
I would appreciate any detailed information you can give me, or if you can recommend a good site .....
Thanks
Old Jun 24, 2006 | 10:57 PM
Dave01's Avatar
Default RE: Brake replacement guidance
Here is a decent guide:
http://www.vbandp.com/instructions/h...t/97000-01.htm
Also, check here for reasons why I chose slotted rotors over plain (prone to uneven brake pad deposits and pulsating brake pedal) and drilled (prone to cracking):
http://forums.corvetteforum.com/show....php?t=1410305
Dave
Old Jun 25, 2006 | 10:29 AM
That site seems to explain it all very well. I appreciate your help.
Todd TCE
Aug 25, 2015 09:55 AM
RudeDog
Jul 29, 2007 07:12 PM
gracing76
Feb 1, 2007 01:01 AM
swampfox
Sep 15, 2005 06:47 PM
tsaun56
Jun 30, 2005 12:25 AM
