Rear Brake Rotor Replacement Questions
Old Jan 28, 2007 | 05:23 PM
gracing76's Avatar
Default Rear Brake Rotor Replacement Questions
I've got a 1976 Corvette, that I am currently rebuilding/customizing. Now my question is how do you get the rear brake rotors off?!? I drilled off the rivets that hold the rotors onto the hubs on both the front and rear. I got the front rotors off with little effort. Now the rear rotors have been nothing but trouble. First I drilled the rivets off and the drilled inword about a 1/4" into the rivet studs, but the rotors still do not want to budge. I am not going to use the old rotors so I have not been worried about damaging them at all. I have heated them up with a torch, drownded them with penitrating oil, pried, hammered and cussed, with no luck. So any help in this matter will be great. Thanks, Dan.
Old Jan 28, 2007 | 07:50 PM
78buckshot's Avatar
Default RE: Rear Brake Rotor Replacement Questions
I did'nt have much trouble with my 78 rears but I had a similar problem on my wife's Expidition. I used a large two jaw puller with quite a bit of tension on it and kept heating the rotor in the center with a rosebud tip, once it reached the temp it needed to expand, it popped off,good luck and be carefull.
Old Jan 31, 2007 | 05:51 PM
gracing76's Avatar
I got both of the rear rotors off last night (thank God). I had to use a little more heat and I drilled the studs out a little bit more. Thanks for your help, Dan.
Old Feb 1, 2007 | 01:01 AM
The factory rear rotors were trued after attached to the hubs. Therefore when you put the new ones on, you will want to check the runout at each of the five mounting positions. I believe the spec was 0.005" max but not sure. If you have too much runout, it will move the pistons back and forth in the caliper bores and will eventually cause air to be pumped in. This will result in spongy brakes at best and no brakes at worst.
Recommend installing the stainless steel parking brake kit. Stainless crossover cable is a good idea also.
budman30562
Jan 19, 2009 08:01 PM
najaf4life
Oct 18, 2008 06:52 PM
Ravensfootball
Feb 10, 2008 11:25 PM
LT4Dave
Dec 11, 2006 04:26 PM
cboegoforth
Aug 12, 2006 10:21 PM
