c5 '02 tire monitor system reads low presure
Old Mar 19, 2013 | 05:17 PM
AZScott's Avatar
Question c5 '02 tire monitor system reads low presure
Read a lot of threads, but haven't seen an answer to this question. What happens (what does the dash show) when the tire monitor system sensors in the rims run out of juice. (batteries go bad.) This is on a C5 2002. Do they show erratic pressure, show low pressure, or all of a sudden stop showing anything ?
Had them just programed by GM dealer with the fancy tool. But the fronts are showing 10 and 18, and I know they both have 30. Not sure if it is batteries, or something else. Thanks for your help !
Old Mar 19, 2013 | 07:16 PM
AZScott's Avatar
One thing to add, I have had enough miles and speed, for them to be showing actual pressures.
Old Mar 27, 2013 | 10:38 PM
Dave01's Avatar
I found this, a while back:
The sensors can't be "calibrated", they send the ABSOLUTE tire pressure, which is then "adjusted" by the Barometric pressure (obtained from the PCM) at the RFA. The RFA then transmits the "corrected" pressures to the IPC via the vehicle's data bus.
If you are still getting invalid readings (and you are SURE they are wrong) then the batteries in the TPMS are probably getting weak and need to be replaced.
derekholland
Sep 25, 2009 01:07 PM
bellrock1952
Jul 4, 2007 03:08 PM
jaminjo
Jan 18, 2007 08:30 PM
2001c5
Nov 29, 2006 08:42 PM
bp4286
Aug 22, 2006 11:22 PM
