c5 rotors warping
Old Jul 16, 2007 | 10:24 AM
fjf0302's Avatar
Default c5 rotors warping
i am new here.
i have a 03 vette. the rotors warp after 10k miles. iwant to replace them with ones that dont warp. are slotted or drilled rotors any better than oem?
Old Jul 16, 2007 | 02:20 PM
extanker's Avatar
Default RE: c5 rotors warping
if your rotors are warping after 10 k there is a problem and it may carry over to any upgrades
Old Jul 16, 2007 | 07:39 PM
tankerpilot01's Avatar
Exactly....I use the Napa $25 rotors on the track and they don't warp....I'm thinking one of the smarter guys on here will have a guess...but something must be up with your brakes themselves that is causing you to do that to your rotors???? I'm curious as to what that could be myself......
Old Jul 18, 2007 | 01:25 PM
fjf0302's Avatar
the original rotors warped after 10k miles. i lived with the pulsating until brakes were needed at 35k. Chevy dealer did the replacement of brakes and cut the rotors. again 10k until pulsating started. so these are still the original rotors and only Chevy installed pads. no heavy driving or track. now that im at 70k i need brakes again, so i want to do the job myself and use new rotors. just dont know what to use.
Old Jul 18, 2007 | 02:28 PM
extanker's Avatar
stock rotors will be fine for you,use TQ wrench and star pattern on lug nuts.drive gently for 200/300 miles so brakes bed in
Old Jul 20, 2007 | 02:39 PM
Dave01's Avatar
Ah, the dreaded pulsating rotor syndrome. I know it well.
You might want to read this:
http://forums.corvetteforum.com/show....php?t=1410305
Bottom line: Some types of pads will transfer uneven deposits of pad material to the rotor. The OEM rotor is not warped, but the pad deposits make the pulsating pedal simulate a warped rotor condition. Any plain rotor, including the NAPA $30 one, will do the same thing with those pads. Some people find that ceramic pads solve the problem, but I waswn't going to take a chance, so I solved my problem permanently. How? Read the linked post!
Dave
Old Jul 20, 2007 | 03:00 PM
pewter2000's Avatar
GREAT INFO DAVE! my breaks are pulsating but i'm living with it for now untill i'm ready to change out pads & rotors (which is pretty soon)... i agree w/ your info regarding drilled vs. slots...i've done trial and error back in my "ricer" days w/ both options...and of course i went w/ the drilled first because of all the hype regarding "better stopping power due to less heat"...but of course you know the story...they cracked...so thumbs up to slotted rotors!
Also...crusing through ebay i saw a set of 4 brand new slotted rotors w/ pads a couple days ago...you may want to check it out before you spend too much money elsewhere...especially if you're gonna do the work yourself...
Old Jul 21, 2007 | 09:48 AM
Dave01's Avatar
Dan,
PowerSlot also makes dimpled and slotted rotors. The dimples are FAR less likely to allow crack propogation, but as you know, those dimples are for looks, only. When you do buy rotors, avoid those made in China - many are made of inferior steel. Also, the cadmium-plated rotors, like the PowerSlots, will look nice far longer than unprotected or zinc-washed rotors. Yes, you pay for the extra protection, but in all likelyhood, a good set of rotors will last a long time. I don't expect to change my cryo PowerSlots for the next 20 years!
Dave
Old Jul 21, 2007 | 10:26 AM
pewter2000's Avatar
looks like i know which rotors to look for now! thanks dave!
c4vettegirl21
Jan 23, 2007 04:11 PM
srizzutto
Jun 16, 2006 09:20 PM
Mudwrestler
Jun 11, 2006 11:00 PM
Petew1971
Mar 7, 2006 02:04 AM
gmbrasco
Oct 23, 2005 04:17 AM
