1999-flushing the cooling system
Old Jul 18, 2007 | 06:48 PM
zora55_56's Avatar
Default 1999-flushing the cooling system
Need to know if there is any special methods or products that should be used. I know that certian antifreeze will deteriorate components.
Old Jul 20, 2007 | 04:26 PM
b777_uk_2000's Avatar
Default RE: 1999-flushing the cooling system
You want to use Dex-Cool coolant. To flush I drained out as much as I could then re-filled with water. Ran the engine to operating temp tp get the water circulating and then drained again. I did this until there was pretty much just water in the system. Then refill with the Dex-Cool/Water mix. I found that there was quite a bit of water left in the system (can't remember exactly how much) when drained so you need to addan adjusted amount of coolant mix.
Old Jul 20, 2007 | 05:38 PM
bados's Avatar
You'll need to know what the water jacket holds.
Old Jul 21, 2007 | 02:13 AM
ORIGINAL: b777_uk_2000
I won't have tap juice left in my twister after doin' a flush. Too many chemicals in it. AND, you don't know how much is actually left.
I'll put a shop-vac on every hose. It'll pull 3 more quarts from a GM 350, and almost as much from a GM 4.3L. Nasty jam[:'(]. Not circulatin' in my stuff.
Old Jul 21, 2007 | 10:54 AM
I think you are supposed to use distilled water. I chose not to do this and I may regret it, we'll see. W.r.t knowing what was in the systemI just paid attention to the amount of fluid I drained out, subtracted this from what the system is known to hold (in the factory handbook, along with fluid type) and then topped back up. Took the car for a run to get everything circulating and thoroughly mixed. The C5 is not that easy to disconnect all pipes and hence this route seemed affective.
Old Jul 21, 2007 | 11:08 AM
Very true, b7.
Some municipalities use a very high concentration of chemicals in tap water. In our bodies, there are no chemicals which will bond [chelate] with tap chemicalsto form particulates. Not quite so, is the case with tap chemicals and coolant chemicals.
I know that one cause I missed that question on the organic chem test. I won't miss it again.
RobRod
Sep 3, 2008 11:06 PM
blueshark
Dec 25, 2006 09:23 PM
bertsbassbox
Aug 17, 2006 06:27 PM
350ZNV
May 8, 2006 05:58 PM
imb1987
Feb 8, 2006 12:38 PM
