C6 Grand Sport Wheels
Old Nov 8, 2025 | 11:51 AM
corvette JR's Avatar
Default C6 Grand Sport Wheels
I am buying a 2002 Torch Red Base model Corvette Monday, it is completely stock with 33k on the clock I would like to put C6 grand sport chrome star wheels 18 front 19 rear what is the best way for the set up? 20mm rear wheel spacers maybe? and what sizes Michelin tires front and rear should i buy, and will this work? thank you in advance i am 66 years old and i have not had a vette since i was 25 years old back then it was a red 1982 cross fire injection corvette
Old Nov 9, 2025 | 08:23 PM
Welcome to the forum. You could check with Tire Rack. I'm not sure they still do but they used to be able to answer questions like that.
Old Nov 24, 2025 | 02:07 AM
hikoma's Avatar
Originally Posted by corvette JR
I am buying a 2002 Torch Red Base model Corvette Monday, it is completely stock with 33k on the clock. I would like to put C6 Grand Sport chrome star wheels 18 front 19 rear, and I’ve been researching setups and even looking at genuine BMW parts online for reference. What is the best way for the setup? 20mm rear wheel spacers maybe? And what sizes Michelin tires front and rear should I buy, and will this work? Thank you in advance i am 66 years old and i have not had a vette since i was 25 years old back then, it was a red 1982 cross fire injection corvette
Hello. You can use C6 Grand Sport wheels 18 front and 19 rear on your 2002 Corvette. Hub-centric spacers are recommended if needed, but 20 mm in the rear may cause rubbing, 5 to 10 mm is safer. Tire sizes: Front 275/35R18, Rear 305/30R19 or 315/30R19 depending on wheel width. Ensure proper torque, quality spacers, and get a professional alignment. This setup will work if installed carefully.
Old Nov 25, 2025 | 03:38 PM
Hikoma: Welcome to the forum.
sistrunk05
Apr 25, 2021 01:14 AM
druby
Mar 3, 2013 05:10 PM
MarkP
Mar 31, 2009 03:04 PM
MRDETROITMETAL
Sep 20, 2007 01:11 PM
