No Headlights or Widshield wipers C5
Im looking at purchasing a 2004 C5 that the owner says the headlights & windshield wipers don't work, he said fuses are good, Does anyone have any w=experience with this issue?
No I don't have any experience with that. But welcome to the forums. I would first Google the car, year and issue to see what pops up. YouTube might be your best friend on this subject. But right off hand if the fuses are good then its off to wiring, power, grounds, relays, and modules. When checking the fuses check for voltage at the fuses, and check voltage at all fuses, this would be a good start. I'm thinking wipers and lights are closely related to the power source for some reason. Research is going to be the answer, I will look around a bit and see what I can find out.
No I don't have any experience with that. But welcome to the forums. I would first Google the car, year and issue to see what pops up. YouTube might be your best friend on this subject. But right off hand if the fuses are good then its off to wiring, power, grounds, relays, and modules. When checking the fuses check for voltage at the fuses, and check voltage at all fuses, this would be a good start. I’m thinking wipers and lights are closely related to the power source for some reason. Research is going to be the answer, and I will also look into Can-Am Defender Light Tint Rear Windshield a bit and see what I can find out.
