Check out this video!
Old Aug 3, 2006 | 01:36 PM
  #11
TopSpeed's Avatar
Default RE: Check out this video!
ORIGINAL: rjensen
Hi Dave,
Okay, here comes the dumb blonde question: "How do you shift an auto tran manually??? Without a clutch, I'm clueless.
Thanks in advance . . . your input is always greatly appreciated.
Rita
No such thing as a dumb question, only dumb answers. When at a light, put your shift lever into the "1" position. Mat the pedal. *big smiles at this point are highly recommended*. Push the shift lever forward and move it into the "2" position when your RPM of choice it hit. This will hold the tranny in 1st gear until you have hit the right RPM. This also works the other way; say you're in 3rd or whathaveyou and you are coming up on a twisty section you'd rather be in 2nd for, to have the RPM right in the sweet spot in the power band so when you drop the hammer, the beast let's loose. Slide your shift lever into the "2" position, and you will sing around that corner in 2nd.
Beware. These cars rev VERY fast, and driving it up in the power band WILL result in 1) massive acceleration, 2) big smiles all 'round.
I hope this answers your question, rjensen, but don't hesitate to raise your arm if you need clarification or have a followup...
Old Aug 3, 2006 | 10:23 PM
  #12
rjensen's Avatar
Hey, TopSpeed -
Thanks so much for this explanation. My other ride is a Toyota 4Runner and I can tell you from experience, this kind of shifting doesn't work in a 4Runner. I know, ever since one of my dogs smelled a bird and came flying over from the backseat to the frontseat and inadvertently hit the stick and shifted gears [] That was not a good day.
Thanks again. I think I'm still a little leery of trying this in my Vette.
Take care.
Old Aug 3, 2006 | 10:43 PM
  #13
1stock97's Avatar
Great vid
Old Aug 4, 2006 | 01:45 AM
  #14
Dave01's Avatar
ORIGINAL: TopSpeed
ORIGINAL: rjensen
Hi Dave,
Rita
I couldn't have said it better!
Old Aug 5, 2006 | 04:12 PM
  #15
Pecemkr's Avatar
Top Speed,
what's the safest way to wind down the speed after you've done this manuever with the auto tranny? Do I just stick it in "D" Drive? Do I just slam on the breaks? I take it that after reaching 3rd gear I'll be going pretty fast. Your advice?
Pecemkr
Dec 21, 2006 12:14 AM
Z 51
Nov 17, 2006 07:42 PM
corvette king
Oct 19, 2006 02:53 PM
gorichb
Sep 22, 2006 02:30 PM
DBOWERS
Aug 31, 2006 08:39 PM
