Code P0803 & P1575
Old Sep 19, 2007 | 10:48 PM
tankerpilot01's Avatar
Default Code P0803 & P1575
I keep getting the P0803 code "1-4 upshift solenoid circuit malfunction" or "control circuit M/T" whatever the M/T means, I don't know.....depending on where you look. I have the CAGS eliminator harness plugged in.....and it supposedly was supposed to work and prevent DTCs. Is that causing this code that is turning on my "Check Engine" light? I'll clear it out, then it will come back.....sometimes with an H (in the history I think??) and sometimes with a "C"? Not sure what the C means.....
Also I've seen a P1575 "Extended Travel Brake Switch Circuit High Voltage"....no clue what that means???? It also had an "H".
Just seeing if anyone has some insight for me. Thanks!
Old Sep 21, 2007 | 10:36 PM
Dave01's Avatar
Default RE: Code P0803 & P1575
Kevin,
Did you try removing the CAGs bypass? Do that and see f the code pops up again. M/T probably means "Manual transmission". As far as the other code, try typing it in as a Google search to see if it shows up in a forum discussion. I'll bet it has.
Dave
tankerpilot01
Apr 14, 2008 07:11 PM
mdsbch
Oct 12, 2006 01:20 PM
94corvette
Dec 4, 2005 01:38 AM
Lee Willis
Nov 30, 2005 01:40 PM
jsteezy1290
Jul 28, 2005 12:28 AM
