Code PO174
Old Sep 12, 2007 | 08:10 PM
lbelew's Avatar
Default Code PO174
Hello guys, getting a PO174 once a week in a held status. Don't own a service manual, so what's the easy fix, understand that this indicates fuel trim system lean bank 2.Thanks.
Old Sep 14, 2007 | 11:13 AM
oliwa22's Avatar
Default RE: Code PO174
Try reading this. Hope this works
[hr]
DTC P0174 Fuel Trim System Lean Bank 2
Circuit Description
The powertrain control module (PCM) controls a Closed Loop air/fuel metering system in order to provide the best possible combination of driveability, fuel economy, and emission control. The PCM monitors the heated oxygen sensor (HO2S) signal voltage and adjusts the fuel delivery based on the signal voltage while in Closed Loop. A change made to the fuel delivery changes the long and short term fuel trim values. The short term fuel trim values change rapidly in response to the HO2S signal voltages. These changes fine tune the engine fueling. The long term fuel trim values change in response to trends in the short term fuel trim. The long term fuel trim makes coarse adjustments to fueling in order to re-center and restore control to short term fuel trim. You can use a scan tool in order to monitor the short and long term fuel trim. The ideal fuel trim values are around 0 percent. A positive fuel trim value indicates that the PCM is adding fuel in order to compensate for a lean condition. A negative fuel trim value indicates that the PCM is reducing the amount of fuel in order to compensate for a rich condition. If the PCM detects an excessively Rich or Lean condition, the PCM sets a diagnostic trouble code (DTC). The long term fuel trim diagnostic parameter is an average of several of the long term speed load learn cells which the PCM selects based on the engine speed and the engine load.
Conditions for Running the DTC
[*]DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0125, P0200, P0300, P0335, P0336, P0351-P0358, P0410, P0412, P0418, P0443, P0500, P0502, P0503, P1120, P1220, P1221, P1258, P1415, P1416 are not set.[*]The engine coolant temperature (ECT) is between 50°C (122°F) and 115°C (239°F).[*]The fuel trim (FT) is enabled.[*]The barometric (BARO) pressure is greater than 74kPa (10.7psi).[*]The mass air flow (MAF) is between 5.0grams per second and 90g/s.[*]The manifold absolute pressure (MAP) is between 26kPa (3.7psi) and 90kPa (13psi).[*]The intake air temperature (IAT) is between -20°C (-4°F) and 90°C (194°F).[*]The engine speed is between 400RPM and 3000RPM.[*]The TP sensor angle is less than 90percent.[*]The vehicle speed is less than 137km/h (85mph).[*]The fuel level is greater than 10percent.[*]All of the above conditions met for 6.0seconds. [/ul]
Conditions for Setting the DTC
The PCM detects the average Long Term Fuel Trim cell values are above a predetermined threshold.
Action Taken When the DTC Sets
[*]The PCM illuminate the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails, if the diagnostic fails under the same conditions, such as the load, the RPM, or the temperature as the previous ignition cycle that the test ran and failed.[*]The first time during which the diagnostic fails, the PCM records the operating conditions in Failure Records.[*]The second consecutive ignition cycle that this diagnostic fails under the same conditions such as the load, the RPM, or the temperature as the previous ignition cycle, that the test ran and failed, the PCM stores this information in the Freeze Frame. The PCM copies any data that was previously stored in the Freeze Frame and copies the data into the Failure Records. The PCM then overwrites the Freeze Frame. The only exception to this is if a Misfire DTC was already recorded in the Freeze Frame. In this case, the Misfire data stays in the Freeze Frame and the PCM updates the Fuel Trim data in the Failure Records. [/ul]
Conditions for Clearing the MIL/DTC
[*]The PCM turns the MIL OFF after three consecutive ignition cycles during which the diagnostic runs and does not fail within the same conditions that the DTC last failed.
Important
If the last failure was during a non-typical driving condition, the MIL may remain ON longer than the three ignition cycles. Review the Freeze Frame/Failure Records for the last failure conditions.
[*]A History DTC clears after forty consecutive warm-up cycles, if this or any other emission related diagnostic does not report any failures.[*]A last test failed (Current DTC) clears when the diagnostic runs and does not fail.[*]Use a scan tool in order to clear the MIL/DTC. [/ul]
Diagnostic Aids
Important
[*]Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.[*]For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems. [/ul]
[*]This DTC sets if the engine runs out of fuel.[*]A fuel delivery malfunction causes this DTC to set. Thoroughly inspect all of the items that cause a lean condition.[*]For an intermittent condition, refer to Symptoms . [/ul]
Test Description
The numbers below refer to the step numbers on the diagnostic table.
[ol]
This test determines whether the fault is present.
Using the Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature , etc.) that you observed. This will isolate when the DTC failed.
If DTC 171 is also set indicates both banks of the engine are operating lean. Inspect items that would cause both banks to operate lean.
A vacuum leak will cause DTCs P0171 and P0174 to set at the same time. Inspect all areas of the engine for a vacuum leak. Also inspect PCV valve for being the correct one for this application. Make sure the engine oil fill cap is in place and that it is tight. Inspect that the engine oil dip stick is fully seated.[/ol]
Step
Action
Values
Yes
No
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
Important
If any DTCs are set, except P0171 and P0174 refer to those DTCs before proceeding with this diagnostic.
[ol]Install the scan tool.
Start the engine and idle at the normal operating temperature.
Fuel system in Closed Loop.
Monitor the LT FT Bn 2 display on the Fuel Trim Data List using the scan tool. [/ol]
Is the LT FT less than the specified value indicated?
23% LT
Go to Step 3
[URL=http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=554261&
Old Sep 14, 2007 | 11:15 AM
oliwa22's Avatar
OOPS, I just noticed a file upload. Next time I'll send an atached file. Sorry if this caused any inconvenience for anyone.
Old Sep 17, 2007 | 01:08 PM
lbelew's Avatar
Thanks for all of the info. Just replaced the A/C belt and may have knocked something loose during the process.
Old Sep 19, 2007 | 08:41 PM
lbelew's Avatar
Found a hole in the PCV to throttle body hose. Luckily an easy fix.
mdsbch
Oct 12, 2006 01:20 PM
kggoodier
Jun 13, 2006 01:34 AM
94corvette
Dec 4, 2005 01:38 AM
Lee Willis
Nov 30, 2005 01:40 PM
jsteezy1290
Jul 28, 2005 12:28 AM
