Convertible Top Glass Unglued
Old Jun 29, 2007 | 09:45 AM
jbihl's Avatar
Default Convertible Top Glass Unglued
I have a 2000 convertible that the back glass has come loose from the rubber strip that held the glass in place.Neither the glass nor the rubber strip appears tohave an adhesive residue on them.How was it attached from the factory? I assume that I am not the only one that has had this problem. Does anyone have a fix?
John
Old Jul 1, 2007 | 05:30 PM
MY02VET's Avatar
Default RE: Convertible Top Glass Unglued
Most shops will tell you it can't be fixed but I have seen posts on the "other" forum by people with your problem that have sucessfully glued in back in place. I can't remember the product they used but I'm sure you could do a search on this forum or the "other" forum about Corvettes and find the solution to your problem. Many people just replace their tops but if yours is still in good condition I would recommend re-glueing the window. In case you don't already know, a new top sells for about $500.00 plus about $500.00 for the install.
Good luck solving your problem!
DV8
Jan 12, 2013 10:21 PM
goforit
Aug 1, 2008 08:47 PM
cvette
Sep 7, 2006 10:05 PM
creed02
Aug 27, 2006 04:42 AM
Lenticular
Oct 3, 2005 03:48 PM
