Engine "Ping" or knock
Old Sep 15, 2005 | 05:43 PM
faspgh's Avatar
Default Engine "Ping" or knock
I have a 2000 corvette 6 speed. The engine pings or knocks in higher gears on load. I use 93 octane fuel. Has anyone experienced this and found a remedy?
Old Sep 15, 2005 | 10:48 PM
Default RE: Engine "Ping" or knock
No, not on any of four LS engines I've owned and abused. Real pinging or knock should not happen unless something is wrong.
If you are sure it is pinging, I'd take it to someone with a good OBD diagnostics set up, maybe even LS1 edit, and have them check everything over.
Old Sep 20, 2005 | 03:20 PM
zoonsf's Avatar
I have a 99 hardtop and think I'm hearing the same thing as you. It's doesn't sound like a loud "ping" but a small ticking sound in high gears at very low RPMs... Its done it for years now and I've never worried about it much. Maybe I should, but it hasn't caused me any grief luckily. It's so faint that people often can't hear it though.
Old Sep 20, 2005 | 09:18 PM
It might be "piston slap," I've been told that earier LS engines had a bit of "rattle" at low RPM, high torque situations due to the "hypereuteric" (or however its spelled) pistons have a bit of play. It caused some owner concern but was not serious. I never had it myself or even heard it in a car but it was supposed to be there is some -- but no big deal.
Old Sep 24, 2005 | 02:48 AM
Dave01's Avatar
I've heard that Seafoam does a good job of getting rid of carbon buildup on the pistons. Otherwise, throw in some concentrated Techron just before filling the tank. Do this before every oil change to keep carbon buildup to a minimum.
jglynn623
Mar 16, 2013 07:40 PM
repodude43
Jul 10, 2007 12:59 PM
07c66speed
Corvette C6 Z06
May 2, 2007 01:49 AM
bill
Jul 8, 2006 12:18 PM
mjjansson
May 23, 2006 03:25 PM
