evaporative system leak
Old Mar 2, 2007 | 07:59 PM
hardluck's Avatar
Default evaporative system leak
Have a evaporative system small leak code on my 00. I've been told they usually are caused by the gas cap. I've retightened my cap acouple of times and then reset the code to off and it will still pop back up every couple of days. Does anybody have any easy tests to determine what else it could be or any other ideas on what it could be? Thanks in advance.
Old Mar 2, 2007 | 10:55 PM
78buckshot's Avatar
Default RE: evaporative system leak
Try putting a small amount of grease on the o-ring on the gas cap, if thats the site of the leak it should seal up, if not, start checking all of the rubber vacuum hoses for cracks and/or a disconnected hose.
Old Mar 3, 2007 | 12:22 AM
hardluck's Avatar
Thanks for the tip Buckshot. I'll give it a try.
Old Mar 3, 2007 | 12:06 PM
These leaks are so common, and so impossible to fully fix, that most states (like mine, NC) that do emissions inspection via reading the OBD codes electronically rather than actual testing the car, will forgive this code. It is often the filter canisters or something, not just the filler cap. I would not worry about
Old Mar 3, 2007 | 03:15 PM
hardluck's Avatar
Thanks Lee for your input. Is there a perment way to delete the code so it does"t keep popping up?
Old Mar 6, 2007 | 08:55 PM
Evap small leaks usually trace back to either the vent solenoid or cannister purge solenoid, or gas cap. Tightening gas gas cap usually won't fix your problem. We test these evap leaks 2 - 3 times a week on a variety of autos, but we use a smoke machine to test with, usually fairly easy to find if you have the right equipment. Shotgun approach to fixing it gets expensive. Good Luck. [8D]
Old Mar 7, 2007 | 05:21 PM
hardluck's Avatar
Thanks Mech 259. I,ve retightened my gas cap acouple of times and so far it hasn,t come back on. But I'm still keeping my fingers crossed. Can the code be turned of permently?
E350
May 22, 2015 01:55 PM
E350
Apr 5, 2015 12:07 AM
dcd58
Nov 10, 2005 08:49 PM
mazie
Oct 3, 2005 12:32 AM
bilt5
Sep 5, 2005 05:47 PM
