LS1 Aftermarket Valve Springs
Old Oct 3, 2008 | 04:01 PM
CJ2000's Avatar
Default LS1 Aftermarket Valve Springs
My First post.
What is a goodset of aftermarket valve springs for the LS1? Any particular brand people prefer or recommend?
Thanks.
Old Oct 3, 2008 | 08:21 PM
Default RE: LS1 Aftermarket Valve Springs
Why would you want aftermarket valve springs? If you change out the cam, or go to high ratio rocker arms, then yes, you need new and stronger valve springs (and pushrods), but get that with the cam, all as a kit with retainers and all the parts you need, as a whole and compatible with one another, allfrom the same manufacturer.
I always liked Crower myself - never have had a problem with them in, oh, maybe 15 built up engines and perhaps 30-40 different cams over many many years. But there are others just as good, I think.
Old Oct 6, 2008 | 10:40 AM
CJ2000's Avatar
LW- Thanks for your reply. Yes, with the intent of changing valve springs the cam would also be changed too. It was actually just a general question about what aftermarket springs would one choose with having done aftermarket work such as cams etc. But I failed to really state that.
So you suggest Crower. Any body else?
tankerpilot01
Sep 13, 2007 08:07 PM
nosty1
May 7, 2007 01:22 PM
jjz28
May 5, 2007 05:40 PM
sd951
Apr 10, 2007 03:21 PM
94blackC4
Oct 12, 2006 02:39 PM
