Need some help with power windows please
Old Jun 27, 2008 | 09:16 AM
newfie_c5's Avatar
Default Need some help with power windows please
Having trouble getting the passenger side window down. When I push on the switch to roll down the window(driver side or passenger switches) I hear a clicking noise. I thought maybe it was the window motor, so I took off the door panel to see what was going on. there is a black box on the door that the wires are hooked too. That box is what is clicking. Does anyone know what this box is called? Or has anyone had similar problems that may know what is wrong here? Thanks
Old Jun 27, 2008 | 09:47 PM
kevette's Avatar
Default RE: Need some help with power windows please
Just had the same thing happen to my car and yes it is the window motor when you order a new one get the motor with the regulator. I can't rember what the black box is called but that is not your problem the click is the relay in the black box. That's where I started too but had someone help me that knew what he was doing ordered the new motor replaced it and its working fine now. Good Luck
Old Jun 28, 2008 | 10:06 PM
byronhunter's Avatar
The black box is the door control. Tap the motor while holding the switchand post back if it moves.
SCHOON
Oct 20, 2012 07:44 AM
SCHOON
Oct 19, 2012 01:57 PM
SCHOON
Sep 10, 2006 05:18 PM
xlwhellraiser
Jul 22, 2006 03:34 AM
corvette king
Apr 11, 2006 01:33 AM
