Headlights won't go down
Old May 17, 2007 | 02:04 PM
Red Pierre's Avatar
Default Headlights won't go down
For what appears to be no reason,when driving in the early morning I put the headlights on (and they did go on), there was no dashboard lights and then when turning the headlights off (and they did go off) the louvers didn't lower. What am I missing?
Old May 17, 2007 | 02:41 PM
jrs 2.0's Avatar
Default RE: Headlights won't go down
check out ecklers .com then search headlights it'll give u an idea
Old May 17, 2007 | 03:11 PM
jrs 2.0's Avatar
what year
Old May 24, 2007 | 03:05 PM
Red Pierre's Avatar
It's a 1998.
Old May 28, 2007 | 10:48 AM
williadg68's Avatar
Your Bright light elements could be burned out, this happened to me once after I replaced my stock lamps with some higher wattage after market lamps. When I turned my headlights on, the headlight doors came up, l ights were on , when I turned the lights off only one door closed, the next day after turning the lights on then off both headlight doors stayed open, I just happened to pull the lever for the bright lights and noticed both didn't work..I put both old lamps back in and everything was ok....I hope this help...I have a 01 Vette
Thank You
Dave
nachocowboy
Feb 28, 2007 04:20 PM
TopSpeed
Sep 7, 2006 03:55 PM
06 Vette
Sep 7, 2006 02:25 PM
maloneys84vette
Feb 14, 2006 12:44 AM
boricua
Jun 29, 2005 11:50 PM
