P0300 random misfire
Old Apr 6, 2012 | 07:57 PM
allencbnc's Avatar
Default P0300 random misfire
im sure this is an old topic but ive got the dreaded random misfire code. compression is 200psi on all cylinders and there are no broken valve springs, i'll pulled the covers for a look see. fuel trim on bank 1 is higher than bank 2. bank 1 is +13 bank 2 is around +3. the unburned fuel smell well melt your eyes. when you first start the engine it does fine for a few minutes the you can feel the misfire start, then the code with flashing check engine light. timing light indicates all coils are firing, noid lights show each injector is being pulsed, you can hear them firing if you stick a screwdriver to them. also put in all new oem ac delco sparkplugs...so, O2 sensor maybe? anybody been there on this issue?
Old Apr 7, 2012 | 01:04 AM
Dave01's Avatar
Most likely, it's a loose spark plug wire but also check the coil pack grounds at the rear of the driver's side head. It has been known to come loose.
Old Apr 7, 2012 | 10:20 AM
allencbnc's Avatar
hopefully. on my way to pick up a Snap-on Modis now to try and pinpoint this issue. nothing like having friends in the business to get diganostic tools like this for ya. fingers crossed.....
Old Apr 7, 2012 | 02:21 PM
allencbnc's Avatar
#5 coil bad....good thing for diagnostic scan tools.....
Old Apr 7, 2012 | 05:34 PM
Dave01's Avatar
Thumbs up
Good to see you found the problem.
CarlN
Dec 11, 2012 09:20 PM
switch75
Apr 14, 2011 10:49 PM
1996corvetteCE
Feb 29, 2008 09:59 PM
85Procharged383
Jan 22, 2008 08:14 PM
markcuc
Oct 6, 2006 04:45 PM
