misfire/popping/rough running
Old Oct 6, 2006 | 03:03 PM
markcuc's Avatar
Default misfire/popping/rough running
i have a 74 stingray, 454. all stock. car only has 35k. i just replaced all valve seals with heads still on the car...not fun. anyway, i adjusted the rocker arms just as anyone else would for solid lifters, but i couldn't find a specific spec for the tollerance. so i took the safe road and set all of the rockers at .019, cold mind you. replaced spark plugs and wires. plugs are factory replacements, same part number r44t i believe, so no gapping was needed. i did not need to assemble the plug wires so there's no problems there. i go to fire it up and i get nothing but misfires and exhaust popping throughout the rpm range. i tried my best to get the engine to warm up to operating temp without blowing anything up and then i adjusted the valves again back to .020, but still same problem with horrible running. any suggestions?
Old Oct 6, 2006 | 04:45 PM
Default RE: misfire/popping/rough running
My best guess is check your firing order, 18436572, and timing.
pushrodracer
Aug 11, 2007 02:03 PM
ernie22golf
Jun 19, 2007 06:32 PM
deansreef
Mar 26, 2007 10:36 AM
dparsons
Oct 5, 2006 09:36 AM
lifelesslived17
Jan 27, 2006 11:34 PM
