Warning Lights
Old Mar 17, 2011 | 10:36 PM
sully's Avatar
Default Warning Lights
I have a 01 Vette. Recently had check engine,traction control and ABS light all come on at once. Checked gauges. Everything OK except for RR tire (has 32psi). Anyone have similar problems? Thanks, Sully
Old Mar 18, 2011 | 11:38 PM
Dave01's Avatar
Sully,
Most likely, your EBCM needs to be repaired. Check the code(s) and report back. Here's how you do it:
http://www.stengel.net/diccodes.htm
If you see 28-CTS or C1214, it could very well be the EBCM. To remove this and send it out for repair, see:
http://www.conceptualpolymer.com/Ele...l%20Module.pdf
Dave
sully
Mar 17, 2011 10:17 PM
pj_80shark
Dec 5, 2008 11:02 PM
shevey
Sep 23, 2008 10:19 PM
IVAN1215
Technical Diagram Help
Sep 24, 2007 01:50 PM
myronp22
Oct 12, 2006 06:26 PM
